Newbie here...
System Posts: 2,511 admin
Hi Guys,
Quick question.. i live in the city and i want to save some money on my bills.. I cant use a windmill, I want to try hooking up a solar power water heater.. can someone please send me some instructions for example how to.... and what is the cost range?
Thanks so much
    Re: Newbie here...
    If you want a do-it-yourself kit... This one appears to be hard to beat:
    www.solarroofs.com
    Solar Guppy has many years experience with a system from them and has been pretty happy. It does require proper maintenance to keep running well and to prevent problems (like freeze damage).
    There have been a few threads here that link back to several extensive home projects--right down to installation photos, and documentation of mistakes and corrections...
    Link 1
    Link 2
    Fpllow the off-forum links. The several projects/websites highlighted are very educational.
    This is an interesting project for a solar heated shed and a control the guy now sells to support a pure DC off-grid solar heating system.
    And this one is a bit more low tech home made heating system. Also very interesting and informative.
    Between the two above links, they probably give the best detailed explanations of how to do a major home heating/domestic hot water project that I have seen.
    The second one is, by itself, probably not practical for a city home system--but both give great ideas of the scope of such projects.
  • System2
    System2 Posts: 6,290 admin
    Re: Newbie here...
    I live in Ontario Canada would you know how much it would be roughly?
    Re: Newbie here...
    Solarroofs.com has price lists (for US delivery)... I am really guessing (don't sell solar, have not bought/built a thermal system myself, and I don't live in Canada), but you should probably budget somewhere between $5-$10,000 for delivery into Canada before even thinking about starting such a system with store-bought components.
    Since you are in an area with Hard Freezes, you are pretty stuck with using an antifreeze based system--more expensive, more maintenance, etc...
    You could use a drain back system (empties collectors of water during freezing conditions)--will work--but not during the winter for you.
    There are evacuated tube type "panels" which will very hot water during very cold weather--but one interesting point from people which make traditional glass/plastic covered panels--snow will thaw quicker on a traditional panel than an evacuated tube type (heat not available to melt snow).
    If you just want home heating--there are some solar thermal panels which you can buy (or even build) that circulate air through the panels and vent it into your home for space heating--a pretty cheap option and you can even build it yourself out of local material to see how it works.
  • System2
    Re: Newbie here...
    Suspect he may have been looking for a $500.00 PV system that would power his hot water heater.
  • Telco
    Telco Solar Expert Posts: 201 ✭✭✭✭✭
    Re: Newbie here...
    Aren't we all.
    Actually, the drainback system should work well in the winter too. My hero here reports temperatures as high as 200+ degrees inside of 10 minutes on a 25 degree day when no fluid was being pumped. Roll to the bottom, the report begins at "Collector Venting." I don't know where this fellow lives, but it looks like he's near the Rocky Mountains, everyone is wearing ski gear, and there's plenty of snow around.
  • System2
    Re: Newbie here...
    Hi Guys, I live in Toronto Ontario we have amazing summers with alot of sun...as for our winters....they get pretty cold... so as per the commets below i would need to purchase a antifreeze based system...
    See i want something that can heat up my water and also provide me some Electricity...
    I see that the solar water heaters are way cheaper then getting solar electricity... i think i will start by finding a solar water system that works for me... which do you guys suggest??
    Also i see below that i can build my own??? is there like a how to step on this?
    again thanks alot :)
    Re: Newbie here...
    Follow the links in the second post... There are two extensive projects shown--photos, parts, mistakes all included.
