Results 1 to 7 of 7
Thread: 12 volt or 24 volt battery bank?
  1. #1
    jawss250 Guest
    Default 12 volt or 24 volt battery bank?
    Is it better to have a 12 volt or 24 volt battery bank for a 3000 watt PV system? What combination of batteries is most efficient / cost effective?
  2. #2
    Default Re: 12 volt or 24 volt battery bank?
    Quote Originally Posted by jawss250 View Post
    A popular question!
    Your system Voltage should not be based on the array size. The whole thing should be designed around the loads. How many Watts do you need to supply at any given time? If it is less than 2kW, you can use a 12 Volt system. The higher it goes, the higher the system Voltage should be in order to reduce the Amps drawn for a given Wattage, enabling smaller DC wiring and less heat generation.
    Size the Inverter according to the maximum Wattage drawn at any one time. The battery bank needs to have enough capacity to supply the daily Watt hour needs (to a maximum 50% DOD). The array & charge controller should be suitable to recharge the battery bank in the (typically) "equivalent 4 hours of good sun". Designing it otherwise leads to disappointments.
    That would depend on what batteries you can get for what price. Sometimes you can buy "golf cart" deep cycles from Sam's Club or Costco for quite cheap, and many here have reported quite acceptable service from them. A good "starting out" battery, as they don't cost much per $ and the FLA-type batteries are more tolerant of "mistakes" in charging & discharging.
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  3. #3
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,953
    For a 3kW PV Array--I would suggest that 24 volt is a minimum (that is around 100 amps charging your battery bank @ 24 volts and would require around 2 MPPT charge controllers; at 12 volts that would be >200 amps and require 3-4 MPPT charge controllers)...
    If you did this at 48 volts, you would only need 1x MPPT charge controllers (around $600 a piece)--That can save you a lot of money (to put into the battery bank and inverter(s)).
    But as Marc says--You also need to look at your peak loads...
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  4. #4
    Join Date
    Sep 2007
    Location
    Telford,Pa
    Posts
    738
    I vote for looking at 48 volts.
    I have a 960 watt array. If I had to do it again, I would be going 24 volts.
    3000 watts @ 12 volts = 250 amps = 5 Charge controllers
    3000 watts @ 24 volts = 125 amps = 2 charge controllers
    3000 watts @ 48 volts = 63 amps = 1 charge controller
    Ken
    Telford,Pa
    Old Homepage: http://home.comcast.net/~n3qik
    Updated 6-7-2009
    Updated Homepage: http://home.comcast.net/~n3qik/site/?/home/
    Updated 12-3-2011
    Home Automation: http://n3qik.homeip.net:5800 Password = guest
    Software/hardware is 100% complete. At least for today. Tomorrow is a different story.
    Updated 2-17-2012
  5. #5
    Quote Originally Posted by bobdog View Post
    ...what's the deal with the charge controllers?
    They can only output 60 Amps regardless of output voltage. Power = Volts times Amps, therefore 12V x 60A = 720 Watts maximum of panels per controller and 48V x 60A = 2880 Watts of panels (roughly). Most popular ones anyway: Outback FM-60, Xantrex XW-60 and Morning Star MPPT-60.
  6. #6
    Join Date
    Feb 2008
    Location
    Gila Wilderness, NM
    Posts
    190
    Quote Originally Posted by AntronX View Post
    Thanks. I felt embarrassed to ask. This stuff is like math in that you have to practice it. And unfortunately I don't keep very good notes or "practice" enough.
    2 Kyocera 130, 2 Kyocera 135, Tristar MPPT 45, SureSine 300, Iota 30r TS, 420 amps battery juice, 5000 watt and 2500 watt gen, lots of wire...
  7. #7
Similar Threads
  1. True power of a 24 volt battery bank relative to a 12 volt bank.
    By TexasDan in forum Off Grid Solar & Battery Systems
    Last Post: April 15th, 2013, 12:17 PDT
  2. How can a 48 volt dc generator be used to charge 24 volt battery bank?
    By solarvic in forum Advanced Solar Electric Technical Forum
    Last Post: February 15th, 2010, 22:56 PST
  3. Best configuration for 2x 24 volt panels and 12 volt battery bank?? (Help a Newbie!!)
    By Mr.Cockburn in forum Off Grid Solar & Battery Systems
    Last Post: December 3rd, 2009, 3:32 PST
  4. 24 volt panel charging 12 volt and 48 volt battery banks
    By Sailiraq in forum General Solar Power Topics
    Last Post: April 21st, 2009, 18:54 PDT
  5. 24 volt battery bank????
    By mark in forum General Solar Power Topics
    Last Post: March 30th, 2008, 22:11 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
