Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Propane Tanks 20lb does not equal 5 gallons (trimmed from another thread)
  1. #1
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    Default Propane Tanks 20lb does not equal 5 gallons (trimmed from another thread)
    i apologize to the op as i have a stupid side question for you guys on propane filling. now it is only 5 gallons and is for my propane grill, but i only went to one place all of these years to fill it. in recent years i began to suspect them of not filling the tank all of the way and charging full price to fill it. other places to fill it are not close by so i stayed at this one place for saving on the gasoline. when they filled it the last time it went to just a bit over 4 gallons on a 5 gallon tank and i burned off any and all that was left inside for this instance. now it needs refilled again and i'm unsure if i should go elsewhere due to being ripped off or not.
    NIEL
  2. #2
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,818
    Default Re: RV Install, wiring advice/help
    Places here in Los Angeles, rip you off. It's a $5 service charge, and about $3 gallon, and 5 gal tanks only hold 4 ga, reserving some expansion space in the tank. I never ger out for less than $22. Blue Rhino exchange is only $29, so when my tank gets nasty......
  3. #3
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    22,002
    Yea--I have gotten to the point where I bring at least two 20 lb (4 gallon effective capacity) tanks to get refilled because some places have a 5 gallon minimum charge.
    I had one guy that stuffed in 5 gallons (doing me a favor?)--and a few days later it was venting propane spray on a warm day (a lot--like in no open fires within 20 feet a lot).
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  4. #4
    Join Date
    Sep 2007
    Location
    Fox, Arkansas
    Posts
    383
    Does a 20# tank hold 20 pounds of propane or doe it weigh 20# total when full? I have always wondered this
    15 assorted solar panels 1800 watts
    MX 60 charge controller
    940 amp hour 2 X 6-100-13 DEKA batterys
    TriMetric battery monitor
    SW4024 inverter
    Basic Stamp computer to control SW4024 from MX60
    MikeO
  5. #5
    Join Date
    Mar 2006
    Location
    Posts
    22,002
    I believe it is 20 lbs of propane. Around 4.24 lbs per gallon of propane.
  6. #6
    Join Date
    Mar 2009
    Location
    Los Angeles, Ca.
    Posts
    1,332
    Quote Originally Posted by mike90045 View Post
    I go to TGP (Trans-Gas Propane) where San Fernando Road meets the 134 fwy (San Fernando & Doran). Technically the address is Los Angeles, but it's right on the border of Glendale.
    http://www.transgaspropane.com/
    I was there a couple weeks ago and the yard price was $1.88/gal. They do have a 5 gal minimum. No service charge. The highest I've seen the yard price was $2.27 last year.
    To neil: I have noticed that when getting my tank filled (5 gal horizontal frame-mounted on a camper van) that if they don't open the bleeder valve enough, the pressure in the tank will stop the filling at less than 5 gallons (usually 4.5 or 4.6), so I always make sure that they open that valve fully. When I do that, the tank takes 4.9-5.0 gal.
  7. #7
    Quote Originally Posted by BB. View Post
    A propane tank can only be filled to 80% of capacity for this very reason. If it is indeed a 5 gallon tank, it can only be filled with 4 gallons of liquid propane. That is the reason for the recent requirement of OPD valves on tanks (OPD = Overfill Protection Device).
  8. #8
    Join Date
    Mar 2006
    Location
    Posts
    22,002
    It is also why they say on the propane tanks to not store them in a garage/home/other place where ignition sources and/or poor ventilation may exist.
    Guess where mine where when this happened ()--fortunately, I was home and heard the noise (venting) before my water heater set off the fumes.
  9. #9
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    wow. ok and thanks for the responses as i just wasn't sure if i was getting ripped-off or not by the quantity being placed into the tank. as far as price goes, it is around $18 (last year) for just a little over 4 gallons so i'm at over $4/gallon. i hope it didn't go up for this year.
    so that the op's thread is not hijacked i ask that you now concern yourself with the op's concerns and any further to me can be added in your post as an after thought or send me a pm on it. my thanks to the op tolerating my side question.
    NIEL
  10. #10
    Join Date
    Mar 2006
    Location
    Posts
    22,002
    Default Re: Propane Tanks 20lb does not equal 5 gallons (trimmed from another thread)
    I think this is a good thread in its own right...
    Trimmed out the Propane Tank questions into own thread.
Similar Threads
  1. SMA-7000 Leg Voltage not equal?
    By bart in forum Solar Beginners Corner
    Last Post: July 20th, 2010, 14:37 PDT
  2. Grounding - Thread-forming vs Thread-cutting screws
    By CHAGA in forum PV Installers Forum - NEC, Wiring, Installation
    Last Post: February 3rd, 2010, 8:37 PST
  3. Replies: 32
    Last Post: October 28th, 2009, 9:09 PDT
  4. Future Energy Prices and Politics (trimmed from other thread)
    By jeffkruse in forum Solar Skeptics, Hype, & Scams Corner
    Last Post: July 24th, 2009, 9:39 PDT
  5. Do It Yourself--Why so many negative comments? (trimmed from another thread)
    By raytech in forum Solar Skeptics, Hype, & Scams Corner
    Last Post: July 15th, 2009, 10:21 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
