Results 1 to 5 of 5
Thread: fuse size for #10 wire
  1. #1
    Join Date
    Feb 2008
    Location
    Gila Wilderness, NM
    Posts
    190
    Default fuse size for #10 wire
    Is it 30 amp or 40 amp max? And how about #6 wire? Thanks.
    2 Kyocera 130, 2 Kyocera 135, Tristar MPPT 45, SureSine 300, Iota 30r TS, 420 amps battery juice, 5000 watt and 2500 watt gen, lots of wire...
  2. #2
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,959
    Default Re: fuse size for #10 wire
    Depends... Are you going with NEC (National Electric Code)? Is the wire type Listed in the NEC? Is it going in Conduit? Conduit Fill Factor? Open Air?
    This chart lists maximum amperage (no insulation type listed) for chassis (open air?) type wiring.
    For example, typically NEC lists 14 AWG as 15 amp fuse. That chart lists at 32 amps maximum. For sending energy any distance, it seems to be very conservative (14 awg = 5.9 amps).
    This chart seems to list generic NEC type ratings (fill factor?).
    If you are going to do this a lot using "house wiring"--then you should get a copy of the current NEC. (no--I don't have a copy ).
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  3. #3
    Join Date
    Feb 2008
    Location
    Gila Wilderness, NM
    Posts
    190
    Thanks Bill., The NEC chart is what I was looking for. I book marked it. It is for the battery bank back to the panel. I am using #10 right now and would like to fuse it at the post via the Blue Sea terminal post fuses that Tony talks about. I ordered a 40 amp and now will ask them to change to a 30 amp fuse.
  4. #4
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,810
    I've always used the romex calc,
    10ga = 30A
    12ga = 20A
    14ga = 15A
    http://tinyurl.com/LMR-Solar
    http://tinyurl.com/LMR-BigLug
    http://tinyurl.com/LMR-NiFe
    Grundfos 10 SO5-9 with 3 wire Franklin motor (1/2hp 240V 1ph # 214505 ) on a timer for 3 hr noontime run - Runs off PV
    Powerfab poletop PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe battery | 15, Evergreen 205w "12V" PV | Midnight ePanel || VEC1093 12V Charger | Maha C401 aa/aaa Charger | SureSine | Sunsaver MPPT
  5. #5
    Join Date
    May 2006
    Location
    Florida, USA
    Posts
    1,275
    The NEC charts are based on heating per foot which does not assure a satisfactory voltage drop for any given total run length.
    Wire types that have multiple layers of insulation like SOOW cord have a lower max current rating for their wire size because of inability to dissipate heat. The heat dissipation also derates for number of current carrying conductors in a conduit/cord bundle which generates more heat in a given confined area.
    Original reasoning was elevated heating will progressively degrade wire insulation, making it brittle. Modern wire insulation is much better at resisting enbrittlement.
Similar Threads
  1. Fuse or circuit breaker size
    By Tradiscantia in forum Solar Beginners Corner
    Last Post: March 29th, 2013, 13:47 PDT
  2. Panel fuse size parallel
    By SolarT in forum Solar Beginners Corner
    Last Post: May 23rd, 2011, 13:42 PDT
  3. In line fuse and wire size
    By Different Drummer in forum Solar Beginners Corner
    Last Post: November 2nd, 2008, 16:44 PST
  4. Fuse size
    By mwilsonnm in forum General Solar Power Topics
    Last Post: January 16th, 2008, 7:34 PST
  5. Grounding and fuse and wire size
    By sunchaser in forum General Solar Power Topics
    Last Post: July 27th, 2006, 4:05 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
