Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Running 10.5 volt modem on 12 volt system
  1. #1
    Join Date
    Nov 2007
    Location
    Wisconsin's Northwoods
    Posts
    85
    Default Running 10.5 volt modem on 12 volt system
    Hi,
    My ISP sent me a broad-band modem to upgrade my service. However, it includes an AC adapter (117AC to 10.5 volt DC/900ma). Since my home is a 12 volt stand alone operation I can't see using an inverter to run this little modem. But I do have a 12 volt power converter with following step-down settings:
    Input: nominal 12 volt
    Stated output: "9 volt (900ma)"
    (meter on it reads 10.3 volts)
    And:
    Stated output: "12 volts (3 amps)"
    (meter on it reads 13.6 volts)
    Question: Can I run the modem off the power converter at the 9 volt setting without damaging it? (again, a voltage meter on it reads 10.3 volts -- darn close to 10.5 volts). Or would I do better using the 12 volt setting? (meter on it reads 13.6 volts). Or is that too high voltage for it to handle? My system voltage gets up to 14.01 volts when the batteries are fully charged. Why they just didn't make this modem 12 volt is beyond me.
    Thanks!
  2. #2
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,290
    Default Re: Running 10.5 volt modem on 12 volt system
    that is an odd voltage. i say try the 9v. it's the higher voltages that would be likely to blow things out and not usually the lower voltages that when they don't work mostly just sit there. out of curiosity, is the voltage the same on it with a load as without if it's possible for you to measure it? i ask this because wall warts usually aren't big on regulation, but some are now the better switching supplies.
    NIEL
  3. #3
    Join Date
    Nov 2007
    Location
    Posts
    85
    Quote Originally Posted by niel View Post
    Do you mean the voltage of the wall power supply unit that came with the modem or the modem itself?
    I'm not sure how to test them under load except that I do have a small digital voltmeter.
  4. #4
    You have to be able to somehow connect the DVM to the modem's power supply while the unit is hooked up and running. That's a bit difficult of course, as the connection between the two is no doubt some type of sealed mini-jack. Can you measure the power supply's open circuit voltage first? It's bound to be higher than the 10.5. And yeah, that's an odd voltage all right!
    But yes; start low.
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  5. #5
    Join Date
    Nov 2007
    Location
    Posts
    85
    Quote Originally Posted by Cariboocoot View Post
    But yes; start low.
    I'll check the power supply's open circuit voltage. That's easy enough.
  6. #6
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,290
    Quote Originally Posted by paulstamser View Post
    that'll be good as it will show the unloaded voltage. if it's high like 13-14v then it is either not regulated or regulated well and putting 12vdc on it with a few series diodes (i'm guessing greater than or equal to 3-4 diodes @ 1 amp or greater) would suffice to run it. each diode will drop the voltage by about .6v give or take and you would not want the voltage configuration you are working on to ever exceed that of your supply voltage as you measured it.
    NIEL
  7. #7
    Join Date
    Feb 2003
    Location
    Green Bay, WI
    Posts
    591
    Ya, I bet it's 9vdc running under load, or darn close to it.
    I agree they should make a standard for all external equipment being 12v or 5v or something standard anyway. It would be nice in a computer room if there were a standard and you could have one 100w power supply feeding a bus that all the peripherals in to. Just think of all the wall warts that could replace and wasted idling transformers... Anyway...
    XW6048, 4 KC 120's, 4 KC 130's and 4 Evergreen 200's totaling 1800w of PV, MX-60 charge controller, Trimetric meter and eight AGM 8A8D's or 490 amps at 48v. 4 tons of geothermal and 3 tons of air source.
  8. #8
    Join Date
    Nov 2007
    Location
    Posts
    85
    I tried to measure the wall wart power supply output but it's DOA. That is, no juice is coming out of it when plugged into my inverter. I know the inverter and voltmeter are good because two other wall wart power supplies give an output reading just fine (one 12 volt unit reads a whopping 19 volts).
    So I called and they are sending a replacement, whenever that arrives.
  9. #9
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,818
    This is how I deal with trying to see what the supply voltage actually is.
    Get 2 straight sewing pins, piece the power cable cord, about 2" apart, one pin on each side, turn unit on, and measure voltage at the pins ! Power off, and remove pins. The pinholes are far enough apart, and so tiny, only imersion in water will be a problem.
    I think the straight battery voltage, when charging, will be too high, and cook something eventually. You can get a 7412 regulator, and set up a trim adjustment to get your 10.5V or , use several 2 or 3 amp diodes in series, you get a bit of voltage drop for each diode, but it will still fluctuate, but it wont be 14.8V anymore.
    http://tinyurl.com/LMR-Solar
    http://tinyurl.com/LMR-BigLug
    http://tinyurl.com/LMR-NiFe
    Grundfos 10 SO5-9 with 3 wire Franklin motor (1/2hp 240V 1ph # 214505 ) on a timer for 3 hr noontime run - Runs off PV
    Powerfab poletop PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe battery | 15, Evergreen 205w "12V" PV | Midnight ePanel || VEC1093 12V Charger | Maha C401 aa/aaa Charger | SureSine | Sunsaver MPPT
  10. #10
    I'd go to Ebay and search for; 10.5v car adapter
    and change the end to what I need if It needed changing...
Similar Threads
  1. Connect 12 volt panels to 24 volt system
    By Marco in forum Solar Beginners Corner
    Last Post: November 23rd, 2012, 10:39 PST
  2. Add Xantrex C60 controller (set to 12 volt) to 24 volt system
    By James in forum Advanced Solar Electric Technical Forum
    Last Post: April 30th, 2012, 9:43 PDT
  3. 48 volt wind generator to charge 24 volt system?
    By krussell in forum Wind Power Generation
    Last Post: February 22nd, 2010, 22:54 PST
  4. 24 volt panel charging 12 volt and 48 volt battery banks
    By Sailiraq in forum General Solar Power Topics
    Last Post: April 21st, 2009, 18:54 PDT
  5. Charging 24 volt system with a 12 volt charger-
    By rickeolis in forum Advanced Solar Electric Technical Forum
    Last Post: March 25th, 2008, 15:48 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
