Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Help understanding Watts and Amp hrs..
  1. #1
    Default Help understanding Watts and Amp hrs..
    I've been googling around and can't seem to find some answers I need to learn. also ordered a kil-o-watt the calculate my wattage later too.
    I'm trying to figure out a few things here. and here they are.
    Can't seem to grasp this watts to amp hrs thing to easy. say I have a 200 ah battery thats (dod just for example). I have one 200 watt panel that puts out say, 19 volts and 11 amps. also say I have 5 hours of good clear sun on a given day, knowing I'll need a charge controller for the battery.
    So in a perfect world it would pump 1000 watts out to the battery in 5 hrs? Also say there is no draw at all, just charging the battery bank.
    Am I thinking right that since this battery is putting out 11 amps, that It would take it around 4 days just to charge the (Dod) 200ah battery @ 5 hrs per day?
    Also , does It make more since to buy 2 100 watt panels than one 200?
    thanks..
  2. #2
    Default Re: Help understanding Watts and Amp hrs..
    What voltage is the battery?
    Watts = Volts x Amps
    Old house - 10 Evergreen 205W panels, Xantrex 4548, XW charge controller, 8 Deka 8L16 batteries (48V 370AH). Trimetric battery monitor. Off grid since June 09 added Grid Support May 2011.
    Current house - New 2.5KW grid tied system being installed.
  3. #3
    Quote Originally Posted by jeffkruse View Post
    Sorry, I knew I left something out....It will be a 12 volt.
  4. #4
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    the answers are here on the forum and here they are again in bold just for you.
    Quote Originally Posted by Sparky View Post
    watts is volts x amps
    watt hours (wh) is volts x amp hours (ah)
    amp hours is amps in reference to 1 hour of time.
    examples; 200 amps for 1 hr = 200ah,
    1 amp for 200hrs = 200ah,
    50 amps for 4 hrs = 200ah
    dod is depth of discharge and is a percentage rating of how far discharged the battery is.
    0% dod is full and 100% dod is dead. if your battery has a capacity of say 220ah and is 50% dod then .5 x 220ah = 110ah
    state of charge (soc) is the opposite of dod and indicates the % of capacity in the battery.
    100% soc is full and 0% soc is dead.
    yes, in a perfect world a 200w pv could give 1000w in 5hrs if under a solar intensity of 1000w/^2, but pv ratings are at 25 degrees c and pvs get much hotter and they get derated, plus many other losses and efficiency factors so forget perfect.
    you are confused in using the terminology as the pv would be outputting the charge current in amps to the battery and i already explained what dod is. now if you are charging a dead 200ah battery, which would be 100% dod, then 4 days at 5hrs per day would be 20hrs of charge time at your specified delivered current rate of 11a and would be 220ah and is 20ah over the charge point in your perfect world. in reality, it would taper the charge current some near the end for a longer timeperiod.
    it soesn't matter unless the 2 100w pvs would cost more than the 200w pv or that the 200w pv is larger in size and the space to mount it in isn't configurable somehow to the 200w pv. an wxample may be for a boat or an rv.
    thanks..
    NIEL
  5. #5
    Quote Originally Posted by niel View Post
    Thank you. I'm not trying to be lazy and have everyone do my work for me. I really do appreciate all of everyone's input.
    I did a search on it here and couldn't find what I thought I wanted.
    After I made my first thread, I've realized I have a ton to learn and don't want to keep making threads day after day....
    And I was going to use a 975 watt coffee pot too..
  6. #6
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    no problem as i didn't make you search for it all, but it was only a reminder to all that it is out there. i admit that it is allot for somebody new to it to grasp.
    NIEL
  7. #7
    I've copied your post to notepad. It will be of a big help to me. I had two choices on my thread, either make one a get the answer or my have wife strangle me for sitting at the PC for countless hours. I got the answer and saved my Marriage too in one thread.
    EDIT......Also, sorry I meant 11 amps that the PV panel was putting out, not the battery...
  8. #8
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,959
    Just to be clear in your first post... you typed about 1,000 watts (5 hours * 200 watts). That should be 1,000 Watt*Hours instead.
    Watts is like Miles per hour or Gallons per hour--it is a rate. When you run the load/generator for 5 hours... then it becomes an "amount" (Watt*Hours, Gallons, etc.).
    Watt*Hours=200 watts * 5 hours = 1,000 Watt*Hours = 1.0 kWatt*Hours
    Note that for many battery system designs, they talk about Amps and Amp*Hours instead of Watts and Watt*Hours.
    The conversion is Amp*Voltage=Watts; Amp*Hours*Voltage=Watt*Hours; etc.
  9. #9
    ZipSnipe Guest
    Hello all newbie here!!!
    So let me see if I got this right, if I have a battery at 12v 51ah which should = 612watts and if I want to run 250 watts of power basically I have about 2 hours worth give or take?
    Also Sears has a battery I'm looking at it say Amp hours at 20hr rate is 115, does this mean its 115ah?
  10. #10
    Join Date
    Mar 2006
    Location
    Posts
    21,959
    To be clear:
    12v * 51 Amp*Hours = 612 Watt*Hours (0.6 kWHrs)
    612 WH / 250 W = 2.448 Hours run time
    However, there are some limits to that calculations.
    Do not run the battery to dead. It will not last very long at all (a few weeks at most). Typically, discharging to 50% capacity will give a longer battery life.
    Batteries are not perfect energy storage devices. They have internal resistance and limits to their chemical processes. Normally, battery capacity is rated at a "20 Hour Rate". So--if a battery is listed as having a capacity of 51 Amp*Hours at a 20 hour rate, it may have a capacity of 35 Amp*Hours at a 2 Hour discharge rate.
    So, putting the above into an equation:
    12 volts * 35 Amp*Hours * 50% (for longer battery life) = 262.5 Watt*Hours of usable capacity
    262.5 Watt*Hours / 250 Watts = 1.05 Hours of useful load
    There are other limitations too... Such as batteries are temperature sensitive.
    • A very cold battery will have much less capacity vs a 77F battery.
    • A very hot (100F) battery will "age" faster than a very cold battery.
    • As a battery discharges, the electrolyte specific gravity falls (Acid+water becomes mostly water). A fully charged battery will not freeze until -90 F. A 40% state of charge battery will freeze around 16F. A 0% state of charge battery will freeze at ~32F.
    • Hot batteries (100F+) self discharge very quickly. Cold batteries (32F and below) will self discharge much slower.
    A couple of battery FAQs to read:
    www.batteryfaq.org
    Deep Cycle Battery FAQ
Similar Threads
  1. Understanding DC grounding
    By eeqmc2 in forum PV Installers Forum - NEC, Wiring, Installation
    Last Post: May 26th, 2013, 12:23 PDT
  2. Understanding the Solar Lingo
    By shmockey in forum Solar Beginners Corner
    Last Post: June 14th, 2010, 16:26 PDT
  3. Understanding Insolation (W/m^2)
    By Tucson in forum Solar Beginners Corner
    Last Post: January 31st, 2010, 11:21 PST
  4. 12 VDC systems 1000 Watts / 24 VDC systems 2000 Watts / 48 VDC systems 4000 Watts
    By GreenerPower in forum General Solar Power Topics
    Last Post: October 17th, 2007, 0:51 PDT
  5. Need help understanding batteries??
    By johnlarn in forum Advanced Solar Electric Technical Forum
    Last Post: September 27th, 2007, 16:57 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
