Performance monitoring and calculating costs based on rate schedule
Is there any way to track up to the minute costs based on one's rate schedule. Say I'm on E6 (peak, part peak, off peak) and I'm using a SunnyBoy inverter. Is there any software that can say connect the WebBox and periodically pull down the data and calculate costs in addition to net usage? Can SMA's SunnyPortal website do it?
Re: Performance monitoring and calculating costs based on rate schedule
The TED claimed a few years ago that they would "shortly" have a net metering solution--haven't seen anything yet.
There is this thing that puts a little opto sensor on your meter's glass case and watches the metal wheel spin--and sends the pulses to a receiver in your home--don't know if can read the direction of spin--or how well it works with an "LCD Wheel"... More questions than answers when I looked at it before.
The problem that I see with the Sunnyboy portal--is, I would guess, only shows the power output of the Grid Tied inverter... I have not seen any reasonable home solution that would give you net readings at the meter.
Which is unfortunate, as PG&E uses a very nice electronic meter (at least for E-7 plan--I assume E-6 is the same meter with different programing) that can very easily download real-time and cumulative readings via an IR interface.
I read about one guy (don't remember where) who had figured out some of the interfacing hardware and software hooks to monitor his own meter. Power company was happy at first, but a few months later he got a notice to remove the optical coupler or they would shutoff his power....
But, perhaps something will be coming around in the next few months (or next year). From this article (April 10, 2008):As you read this, that utility meter outside your house silently spins. Pretty soon, someone from PG&E will come by and enter the numbers into a handheld device. You'll get a bill in a few weeks.
The milkman might be gone, but the meter reader lives.
But not for much longer.
In places like Italy and Bakersfield, in North Carolina and in San Francisco's Twin Peaks neighborhood, the "smart meter" has arrived. In the next three years, it will be here in Silicon Valley, too.
These advanced meters will offer new services, Pacific Gas & Electric says: Your electricity can be turned on or off remotely. The utility will know very quickly if there's an outage. And greater deployment of "time-of-use" rates that price power based on demand will be possible.
And there's a bigger vision. If the scenario unfolds as PG&E executives and others at companies such as Silicon Valley's Echelon foresee, that meter will be able to talk to your home computer. A smart thermostat or energy-management device will connect to intelligent appliances, telling them how to operate most efficiently.
The starting point is that utilities know very little about how much power their individual customers are using.
"Most customers would be surprised that a utility really doesn't know if power is flowing to their home or not," said Don Von Dollen, a manager with the Palo Alto-based, utility-funded Electric Power Research Institute. Installing smart meters represents "the first time we're going to have a communication link to each customer," he said.
In July 2006, PG&E got approval from California's Public Utilities Commission to spend more than $1.7 billion of ratepayers' money to install 10.3 million smart electric and gas meters by 2012. Installation started in December 2006, in the Bakersfield area and Sacramento. Through this week, PG&E had installed about 435,000 smart meters and activated about 115,000.
PG&E is awaiting approval to spend another $625 million on even smarter meters. It's testing some in Twin Peaks to see how well their radio devices communicate in that hilly part of town, which has a plethora of wiring that could mean possible interference.
"Without these meters, we will limit the ability of people to truly change their consumption habits," said Michael Peevey, president of the state's Public Utilities Commission, which regulates PG&E. "However, it doesn't stop at the meters. Once the customer is informed, we must ensure that there is sufficient incentive to get the customer to take action."
That's what's motivating the installation of smart meters: demand response, the industry term for the need to reduce power during critical periods, usually hot summer afternoons.
Getting people to use less power at those times is "the key to demand response," said Jana Corey, director of PG&E's Energy Information Network. Currently, PG&E relies on big commercial customers to cut back when demand is high. Soon it will be able to ask residential customers to help, too.
The goal is to use less energy, but to do it in a way that doesn't affect customers as much as blackouts, said EPRI's Von Dollen.
Here's how PG&E says the meters will work: While old-fashioned meters are read monthly by a person, residential smart meters will be read remotely every hour. Commercial meters will be read every 15 minutes.
The meters will eliminate the need for in-field meter readers, saving the company money. Some of its 900 meter readers will move to other jobs within PG&E. Others will soon reach retirement age, or are temporary workers.
This summer, in Bakersfield, the system will get its real-world test. A voluntary SmartRate program will allow residential customers to agree to much higher rates when demand peaks in return for a discount on the rest of their usage.
"We don't believe in mandatory programs," said Andrew Tang, PG&E's senior director of smart energy web. "We think you can create the right behavior through economic incentives."
Studies have shown, Tang said, that consumers use less energy - perhaps 10 percent less - when they get more information about power needs and costs.
Echelon, a San Jose company, worked with the Italian utility Enel to install a network of 27 million smart meters. Its products are in use from Austria to Australia, in Russia and in North Carolina.
Duke Energy, based in Charlotte, N.C., has started installing 57,500 Echelon smart meters. Besides calculating usage for bills, these meters will include disconnect, pre-pay and time-of-use rate capabilities.
Echelon, which also builds and sells smart thermostats and other home and commercial devices, has a big vision.
Take refrigerators. Right now, said Jeff Lund, an Echelon vice president, your refrigerator doesn't know if it's defrosting during a peak usage period, or what the cost of electricity is at that time. "You don't care when it defrosts," he said. "You just care that your refrigerator isn't frosty."
Not everyone agrees that installing smart meters is a smart decision.
In Bakersfield, the local newspaper and a TV station have had reports from homeowners who said their bills jumped once the smart meters were installed. "Something seems amiss with the smart meters," wrote a local columnist.
Jimmy Blunt said the average bill for his 2,200-square-foot home jumped from $316 to $420 a month after the meters were installed. "It was a little shocking," he said.
He filed a complaint with the PUC, and PG&E has said it will send someone out to check his meter, Blunt said.
"Until they can prove to me that it's not something in their system that's haywire, I don't think it's a good thing," Blunt said.
This concerns a consumer watchdog group, San Francisco-based The Utility Reform Network (TURN), which was against the meters from the start.
"One thing we know for absolute certainty, smart meters mean higher bills," said Mindy Spatt, a TURN spokeswoman. "Meters are not free.
"What we think consumers want are programs that save both energy and money," she said. "It doesn't look like the meters installed in Bakersfield are doing either one."
Paul Moreno, a PG&E spokesman, said the meters are working as touted. He said the complaints are anecdotal, reflecting unusual temperatures and people moving into new homes where they hadn't gotten utility bills before.
"This is not to say our deployment has been flawless, but the problems we have identified either had zero impact on customer bills, or were spotted before the bills went out or shortly afterward," he said.
It might be just worth waiting (or even calling PG&E) to see what the roll-out date is for your area (if one has been scheduled).
Otherwise, I just log my Inverter's daily output, and plug my E7 bill's meter readings into a spreadsheet so that I can make sure that I know how much power my home uses (and watch my peak vs off-peak energy usage--to make sure we don't sneak up over time).
The spreadsheet isn't pretty--but it works. I also run a comparison of year to year output so that I can see if something breaks and drops my power output. It would be nice to have a computer interface (I just type the numbers by hand into a spreadsheet from my daily paper log)--but it just has not been worth the money or electricity (to me) for a small computer to automate the tasks.
- 628 Discussion Forums/Café
