Battery fitment in Camper van
Novaz
Solar Expert Posts: 57 ✭✭✭✭
i have been thinking about using the interior wheel arch boxes of my campervan for putting 4 solar batteries in ,
if i seal them in and make them accesable from the outside would it matter that as they are wired in series that the connections from battery #2 to battery #3 were some distance apart ie the width of the van
i know long wire runs should be avoided but it would give me more room in the van if they are not using extra floor space.
Re: Battery fitment in Camper van
It would depend on the Voltage, current, wire size, and distance involved.
Lower Voltage = more of a problem.
Higher current = more of a problem.
Smaller wire = more of a problem.
Longer distance = more of a problem.
12 Volt system, 300 Amps current, 4/0 wire, 6' distance = not a problem. -
The biggest problem will be balancing the charge.
- 227 Forum & Website
- 135 Solar Forum News and Announcements
- 198 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 617 Discussion Forums/Café
- 310 In the Weeds--Member's Choice
