Results 1 to 5 of 5
Thread: Energy Monitoring System (Kill-a-watt) for the Whole House ..
  1. #1
    Join Date
    May 2009
    Location
    Retirement Capital of CDN & PNW WET Coast
    Posts
    470
    Default Energy Monitoring System (Kill-a-watt) for the Whole House ..
    I have purchased one for trials etc.
    Canuk company . http://www.mtpinc.com/SearchResults....CDT=1369843688
    So far, 3 days in It seems to almost emulate the same readings as the original kill-a-watt.
    When freezer kicks in, 168 watts is added to the MTP system and killawatt jumps to 180 and then cuts down to 170 watts.
    I can turn on any 220v machine and see its added draw.
    Keeps track of my wasting .. After this week I should be able to download it the PC program and analyze it.
    Keeps track of 2 years in day by hr monitoring , every 10 seconds it updates.
    New tech toy 4 VT Spec's = http://www.mtpinc.com/Products.htm?CD=97&ID=616
    VT
    Take back your power
  2. #2
    Default Re: Energy Monitoring System (Kill-a-watt) for the Whole House ..
    Very nice device, and very inexpensive.
    8% error is probably a little bit too high.
    Off-grid: 6.12kW SolarWorld, 8 Trojan IND13-6V, XW6048, 2 XW MPPT60-150, 10kW Generac, 5kW Champion
  3. #3
    Join Date
    May 2009
    Location
    Posts
    470
    8% is a high rate , but the Tech-Rep who I was at a Show with said that the leeway was needed for legality due to the Dumb Spying Meters .
    I have been testing it against with the original kill-a-watt, on 110V draws , with the 220 table saw's plus , when I figure amps/volts to watts , the reported watts added to the existing load on the panel within close range. 8% is a over statement as I have seen.
    Others might find it different. You do need to sync in your 220 voltage , Mine is 224 Volts at dinner time load.
    VT
  4. #4
    Join Date
    Jun 2012
    Location
    Northern CA, 2400 ft. elevation
    Posts
    2,580
    Quote Originally Posted by CDN_VT View Post
    Canuk company .Spec's = http://www.mtpinc.com/Products.htm?CD=97&ID=616
    One serious limitation is that it does not have a voltage waveform reference the way the Kill-a-Watt does, and so can only display VA and not watts.
    The good side of that is that it will show you that whole-house PF correction capacitors really work. :(
    Sunny Boy 3000US, 18 x BP Solar 175b panels, installed 2009.
  5. #5
    Join Date
    May 2009
    Location
    Posts
    470
    Quote Originally Posted by inetdog View Post
    Very true & I read that in the Manual, Still it can give anyone a great one week/month report .
    I'll post my one week trial and see . I have the pool up & working plus all the summer toyz, In a few more weeks the snow shovels will be dusting off again !!
    VT
Similar Threads
  1. Brultech Home Energy Monitoring System
    By RK_Solar_Hopeful in forum Grid Tie and Grid Interactive Systems
    Last Post: November 3rd, 2011, 22:42 PDT
  2. Kill-a-watt
    By icodebot in forum Solar Beginners Corner
    Last Post: July 9th, 2009, 21:57 PDT
  3. One more Kill-A-Watt question
    By PhilS in forum Advanced Solar Electric Technical Forum
    Last Post: March 4th, 2008, 10:22 PST
  4. Kill-A-Watt question
    Last Post: March 1st, 2008, 16:03 PST
  5. Kill-A-Watt
    By Brianellul in forum General Solar Power Topics
    Last Post: August 11th, 2006, 19:47 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
