Results 1 to 8 of 8
Thread: Best deep cycle batteries brands - Are tubular batteries good?
  1. #1
    Default Best deep cycle batteries brands - Are tubular batteries good?
    Hi
    Would like to buy deep cycle batteries and need some help to choose brands.
    I need 2 batteries of 150-220ah each.
    Small installation.
    Also a local small company is selling tubular deep cycle batteries. Are tubular batteries good.
  2. #2
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    Default Re: Best deep cycle batteries brands - Are tubular batteries good?
    ok. we will need more info like the current requirements for the loads, approximate daily loads in ah, and charge current proposed or available.
    i don't know what it is you are referring to as tubular batteries.
    NIEL
  3. #3
    By "tubular" I presume you mean the ones with the coiled plates like Optimas? Nothing wrong with those, providing you get the right ones (Optima has three different types with different colour tops to denote SLI, RV/Marine, and Deep Cycle).
    My personal brand preferences are Crown and Trojan, the former tends to be slightly less expensive.
    At 220 Amp hours (how many Volts?) you could consider the best bargain in golf cart batteries. Sometimes the warehouse stores have these for very low prices and several forum members have had perfectly good service from them. Besides, if something goes wrong and they get ruined you're not out so much money.
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  4. #4
    Quote Originally Posted by niel View Post
    12volts batteries
    Total loads: around 200watts
    Difficult for me to explain tubular types but you can find pictures in the net.
    Thanks.
  5. #5
    Join Date
    Apr 2012
    Location
    Van Horn, TX (West TX)
    Posts
    611
    Optimas not cheap.. and won't get you to that AH without multiple ones..
    I know the maximum AH Optima D31M one is like 75ah..
    I 2nd the idea on 6V GC batteries (sometimes called GC2).. Check Trojan 105's or the likes.. there are 6v each.. just wire 2 of them in series for 12v and theres you 220ah you need.. NAPA sells 8144 and 8146 6v GC batteries for $118 each (+$16 core for each).. and 2 of them will get you similar results.. about 220AH in 12v...
    For 2 of the 8144 NAPA's you'll spend the same $$ as 1 Optima.. about $250-280..
    And there are NAPA's everywhere and you can order online and pick up local..
    Al Z.
    1160 watts PV, 30.86 & -104.792, MidNite Classic 150, Xantrex Pro SW 2000, TS 30 Transfer Switch
  6. #6
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,953
    abdoudiaw,
    I assume you are somewhere around Senegal (Western Africa). So, many times you are looking at what is available locally vs what we would have access to in North America, Europe, etc...
    When you say you have a ~200 watt load--We also would like to know how many hours a day that would be for (and if there is any surge--such as starting a well pump).
    If it is for 2 hours a night (lights, laptop computer, etc.)--that is one thing. If it is 24x7 (such as a radio repeater, computer system, etc.) that is something else.
    In general, if you can get good quality deep cycle batteries (or traction batteries for electric equipment) that are flooded cell (removable battery caps and you have to add distilled water once every month or two)--They are usually the most cost effective.
    Other battery constructions (coiled plate, sealed, AGM, GEL, etc.) have some very nice features (do not need to add water, some have very high discharge current rates--i.e., supplying Uninterruptible Power Supply for computers, starting large motors for trucks, turbines, etc.)... But, they also tend to be very expensive, somewhat easy to damage (over charging, over voltage), and may not last as long as flooded cell.
    Other batteries (truck batteries, "marine batteries", etc.) can also be used--but they usually should not be discharged as deeply (maybe only to 75% state of charge) as "deep cycle" batteries (can go below 50% state of charge)--However, that is sometimes all you can get locally.
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  7. #7
    Join Date
    Oct 2010
    Location
    Nova Scotia canada
    Posts
    2,836
    Quote Originally Posted by abdoudiaw View Post
    Thanks.
    So is this 200 watt load being used 24/7, just a few minutes per day, or several hours per day? What we meed is your total expected watt hours that will be used each 24 hour day.
    1900 watts PV, (1000 watts PV feeding MidNite Classic 150; 900 watts PV + 160 watts micro hydro both feeding into a single shared Morningstar TS-MPPT-60) ; Xantrex Pure Sine 1800/12 for heavy loads; Xantrex Pure Sine 1000/12 on 24/7 for everything else; six Rolls Surrette 2 volt L16 @ 12 volts.
    Domestic hot water totally provided by the sun 8 months out of every year via thermal panel.
  8. #8
    If by "tubular" you mean OPzS types with armoured tubular plates, then yes, they are one of the best battery types for solar- but they are expensive. Check the specification from the manufacturer, it should come with a "How many cycles at 80% DoD rating." Do you know the make and model of the battery?
    Here's an example of an OPzS with tubular plates, monoblock: http://www.systems-sunlight.com/uplo...2_OPZS_100.pdf rated at 1200 cycles with 80% Depth of Discharge.
    2.8kW Yingli PV, 5kW SMA Sunny Island 5048, 900Ah 48V Forklift battery, 5kW Petteroid Indian diesel generator.
    Live data: https://xively.com/feeds/75889/ Blog: http://www.casanogaldelasbrujas.com
Similar Threads
  1. Charging deep cycle batteries under load
    By slyttle in forum Off Grid Solar & Battery Systems
    Last Post: February 28th, 2013, 7:33 PST
  2. Why No Inverters for Deep Cycle Batteries?
    By Jack Kessler in forum Solar Beginners Corner
    Last Post: February 8th, 2013, 21:46 PST
  3. Can I revive my wet cell, deep cycle batteries?
    By rreeves0802 in forum General Solar Power Topics
    Last Post: September 18th, 2011, 15:30 PDT
  4. FS: 12 used GNB Absolyte IIP deep cycle batteries for sale in Atlanta
    By wddanielson@hotmail.com in forum Off Grid Solar & Battery Systems
    Last Post: April 30th, 2011, 22:39 PDT
  5. 76 used GNB Absolyte IIP deep cycle batteries for sale
    Last Post: April 16th, 2011, 8:00 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
