Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: KISS: Find Optimum Winter Tilt Angle or Best Year Round Tilt for Fixed Solar Panel
  1. #11
    Join Date
    Apr 2010
    Location
    Austin, TX, USA
    Posts
    1,862
    Default Re: KISS: Find Optimum Winter Tilt Angle or Best Year Round Tilt for Fixed Solar Panel
    Quote Originally Posted by techntrek View Post
    A question I didn't see asked yet - is this for a grid-tied system or an off-grid system? For grid-tied I would use the angle that gets you the best output year-round. For off-grid use the best angle for winter production.
    I guess many offgridders will use more power in the winter, but I wouldn't think that's universally true.
  2. #12
    Join Date
    Nov 2011
    Location
    central Vermont
    Posts
    2,758
    Quote Originally Posted by rss2q View Post
    Simply put, I just want to find the best tilt that you should mount a fixed solar panel system to receive the best results year round.
    The optimal angle (as techntrek pointed out) may depend on whether you are on or off grid.
    Another consideration is that the optimal direction for you may not be due south. This may be because of local conditions such as fog in the morning or shading in the afternoon, for example. If you are doing a roof mount, and your roof is not facing due south, the calculations for optimal tilt are different.
    Still another consideration (affecting both tilt and direction) may be the timing of your loads. This is true if you are off grid and may be true on grid depending on what net metering arrangements or time-of-use you have. With panels as cheap as they are now it may be cost effective to have split your panels into two arrays (with two charge controllers) with different tilts and directions. If you are using microinverters you might even have more than two tilts and directions.
    rss2q, tell us more about your location, climate, loads, and type of system.
    Quote Originally Posted by ggunn View Post
    I use less in the winter because a large portion of my energy budget is a freezer in a detached (very cool in winter) outbuilding. If I ever get air conditioning or dehumidifier my summer energy use will be still greater.
    --vtMaps
    4 x 235w Samsung, Outback fm60 & vfx3524 & mate, Midnite E-panel, four Interstate L16, Trimetric monitor, Honda eu2000
  3. #13
    Join Date
    Oct 2010
    Location
    Nova Scotia canada
    Posts
    2,837
    Quote Originally Posted by vtmaps View Post
    That's also my experience. The colder the weather the less that freezer runs, thus the less energy used. Come summer my consumption goes way up because the freezer really has to work.
    1900 watts PV, (1000 watts PV feeding MidNite Classic 150; 900 watts PV + 160 watts micro hydro both feeding into a single shared Morningstar TS-MPPT-60) ; Xantrex Pure Sine 1800/12 for heavy loads; Xantrex Pure Sine 1000/12 on 24/7 for everything else; six Rolls Surrette 2 volt L16 @ 12 volts.
    Domestic hot water totally provided by the sun 8 months out of every year via thermal panel.
  4. #14
    Join Date
    Jan 2011
    Location
    Baltimore, MD
    Posts
    157
    But the optimum winter angle will often produce just as much if not MORE power in the summer anyway, even at the less-optimal angle. For on-gridders this doesn't matter, since they can use higher summer production to offset lower winter production, but off-gridders are basically sizing their systems based on the months of lowest productivity, and so it makes sense to optimize to this condition.
    Example: PV watts says that 35 degrees is the optimal angle for year-round production at my location. For a 5 kW system, standard derate, that means a total of 6158 kWh, with 328 in December and 600 in June.
    If I tilt that same array up to 60 degrees, I produce only 5679 kWh per year, but now I produce 365 in December and 459 in June. Tilting the array even more loses production in both summer and winter, unless the snow-glare effect is prevalent.
    It's not a huge difference, but that way I can squeeze a few more kWh into the winter months, when the sun is scarce, and I still generate excess power in the summer months, so who cares about kWh I can't use anyway?
  5. #15
    Here is a great resource. (sorry, US only)
    This page calculates the altitude and azimuth of the Sun (or Moon) at multiple times during any day between 1700 and 2100. Simply specify the object, date, tabular interval, and place:
    http://aa.usno.navy.mil/data/docs/AltAz.php
    Our tax dolars at work.
  6. #16
    Quote Originally Posted by jagec View Post
    This is what I was alluding to in my last post, thanks.
    12 kw Generac, Honda EU3000is, 4.2 kw APC UPS powered either by battery or a Prius. Really.
  7. #17
    Join Date
    May 2010
    Location
    San Pedro de Atacama, Chile
    Posts
    121
    I found this link here on the forum I think. I think it is quite useful.
    http://www.macslab.com/optsolar.html
  8. #18
    If you didn't know shirt from shin-ola you can set the angle by
    1.) know "solar noon" at your local
    2.) use a 12" stake with a true, square 90* base
    and place it on the panels, adjust said panels until there is no shadow.
    Way too simple...
    10-Astronergy 235 watt panels
    Fixed 180* south face-No tracker
    Midnite Solar Classic MPPT Charge Controller 250V
    Mini-Magnum MS4448PAE Power Center
    16(ea) S-530 Surrette Batteries 800aH @ 48VDC 38,400 watt hrs.
    Lat/Long 37.8 N 113.1 W
  9. #19
    Join Date
    Apr 2010
    Location
    Austin, TX, USA
    Posts
    1,862
    Quote Originally Posted by plongson View Post
    Way too simple...
    But on what day? Summer solstice? Winter solstice? Equinox? On the equinox would tell you the optimum tilt for yearly average production if no other factors are in play. Of course, other factors are always in play.
  10. #20
    Join Date
    Apr 2010
    Location
    Austin, TX, USA
    Posts
    1,862
    Of course, most residential roof mounts are on slanted roofs and are for all practical purposes restricted to the azimuth and tilt of the roof. If you installed racking that would mount the modules at a different tilt than the roof, the extra expense incurred would likely far exceed the benefit gained.
Similar Threads
  1. Fall Tilt Angle
    By Coach Dad in forum Off Grid Solar & Battery Systems
    Last Post: September 5th, 2012, 10:50 PDT
  2. Adjusting the tilt angle of my solar array--->novel method proposed
    By Gitchee Gumee Kid in forum PV Installers Forum - NEC, Wiring, Installation
    Last Post: July 29th, 2012, 18:53 PDT
  3. Fixed tilt angle at 41deg. Lat
    By Johnboy777 in forum Solar Beginners Corner
    Last Post: April 15th, 2012, 9:40 PDT
  4. Solar Panel tilt angle...
    By alyaz in forum Solar Beginners Corner
    Last Post: January 6th, 2012, 10:08 PST
  5. Optimum tilt for new fixed system
    By dale in forum Advanced Solar Electric Technical Forum
    Last Post: January 9th, 2008, 4:34 PST
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
