Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: How much concrete footer do I need for a given wind load?
  1. #1
    Default How much concrete footer do I need for a given wind load?
    This structure will hopefully be installed in the fall. the biggest wind load would be on the south North side which is about 65' long and 10.5' tall. made of treated plywood probably 5/8" thickness.
    Will be in Orlando Florida, must be designed for 3 second wind load of 110mph winds.
    how much concrete do I need to pour? Maybe I just have to ask my local building codes people?
    Here is a photo.
  2. #2
    Default Re: How much concrete footer do I need for a given wind load?
    You absolutely have to talk with the local inspector. Ultimately that is who will say "yea" or "nay" to your plan. Even if you have a certified engineer design the foundation the inspector has the final say. Asking him/her is the fastest way to get the 100% correct answer for your area. They will probably also give you specs for hurricane ties as well.
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  3. #3
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,981
    I don't know--but you may also run into problems if the "roof" (panels) are less than ~8' off the ground (or whatever the exact code is) because of the possibility of somebody standing in wet grass and touching a "defective" panel (rated up to 600 VDC above ground). Unless you put a locked fence around the structure (which you would not want to do--I presume).
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  4. #4
    OK, thanks I just wrote an email to the permit dept.
  5. #5
    Well the building codes dept did NOT respond to my email and instead said it would be easier to call me and answer my questions which I thougth was lame.
    Conversation went like this:
    ME: Is a fence is required around the PV?
    HIM: Yes due to high voltage
    ME:how tall does it need to be?
    HIM:It can't be over 6 feet.
    ME: OK, but that' not really what I asked what is the minimum height it needs to be.
    HIM: Typically 4 feet, but with such high voltage you should probably make it 6.
    ME: What do you mean "probably?" I don't want to make a six foot tall fence and then find out it needs to be a different height.
    HIM: Well we've never had anyone make such a big solar PV system so you'd have to submit plans first and get them approved.
    Any other question I asked him about wind loads was basically a useless response like I'd have to get a professional engineer to submit wind load requirements.
    Even a simple question like what type of conduit is required? got me an answer like look it up in the NEC book, I'd hate to misinform you.
    The problem is hiring an engineer is not really economically viable, I might as well buy a unirac system that is already tested.
    I'll probably try to build a shed and then just mount the units on top of it. He seemed to think that was fine and would avoid the whole wind load issue, didn't really make sense to me since there are still wind loads on the panels, just not as much.
    Only problem is I"ll have to call it Solar PV mounting structure since the HOA doesn't allow sheds.
    I wish I could just over engineer the thing instead of having to pay someone to do a bunch of white collar desing work to tell me that I can get away with the lightest metal possible.
  6. #6
    Thank you for once again making me ever so glad I no longer have to deal with such people!
    You might also notice that's another reason why we don't hand out building code advice around here; what's right for one locale is not right for another, and even one that is can be wrong if the half-wit bureaucrat in charge says so.
    Mock conversation with Building Inspector:
    RE: Are you a blinking idiot?
    BI: No. Yes. Maybe. It all depends. You'd better get a professional psychiatrist to assess that.
  7. #7
    Join Date
    Jun 2007
    Location
    Williams Lake, BC
    Posts
    3,388
    Hi RE, I see you did not ask the concrete question..
    IMHO, yes the inspectors are quite vague at times but they normally do concede/defer to a P.Eng. especially to plans with a stamp/seal on them. The seal transfers the legal responsibility to the PE.
    You being in a HIGH wind area , to me, would make it worthwhile, especially to meet that "must be designed for 3 second wind load of 110mph winds" requirement.
    ej
    100% Off Grid @ 51* 46' N lat 124* 44' W long
    New House system: coming - 2 arrays @ 2240W
    CL150&Epanel 2 @140 W 12v PVs , 24V C&D AT-15P AGM @ 950Ah
    + CL150 2@120W 12 V panels, 24V C&D AT-15P AGM @ 950Ah
    Cotek ST1500W inverter, TBS 30a-24v Omni-charger, Honda Eu3000is,
    Guest cabin system: 3 - 70W panels to SB 2000e CC, with 2 - 100 ah 12v SAFT wet NiCd's , 600W TSW Inverter
  8. #8
    Join Date
    Apr 2007
    Location
    Lakeland Florida
    Posts
    1,959
    You are required to have plans stamped by a state licensed professional engineer. This isn't a DIY calculation that this website or the building department would provide.
    This is no code requirements for fencing of ground mounted PV in the State of Florida, and in my county there is no local requirement either.
    You have to find a PE, and submit plans.
    For a roof mount system, it cost me and people I have referred about 250.00 for the review and approved/stamped plans that in my case I did in MS-Paint. For your building it will be allot more as you now have a structure that must be reviewed to meet hurricane codes on top of whatever is need for the PV support and uplift requirements, detailed blue prints will be required for construction which for the permit will require the PE signoff.
  9. #9
    thanks solar guppy! you're right, which is why I'm looking to purchase a solar carport that is preengineered with drawings/windload calcs, etc, which I can buy and DIY install.
    It will cost more than the aluminum structure I was going to build which was wayy over engineered with solid 1.5" square posts, but less than having to hire a PE and get them to approved my custom design.
    Peace, Rolland
  10. #10
    Join Date
    Apr 2007
    Location
    Lakeland Florida
    Posts
    1,959
    You'll need a Florida PE no mater what ... There is no short cuts for this
Similar Threads
  1. Concrete footing size
    By tons001 in forum Solar Beginners Corner
    Last Post: June 21st, 2013, 7:47 PDT
  2. Wind load effect on the PV system
    By Lege in forum Solar Beginners Corner
    Last Post: June 17th, 2013, 13:13 PDT
  3. So THAT's why they do a wind load analysis!
    By jcgee88 in forum General Solar Power Topics
    Last Post: April 25th, 2011, 19:42 PDT
  4. Wind Charge Control / Dump Load Question
    By The Grand Pooh-Bah in forum Wind Power Generation
    Last Post: June 9th, 2010, 10:24 PDT
  5. What to do for a concrete base for 52 pannels
    By t12zh in forum Advanced Solar Electric Technical Forum
    Last Post: April 22nd, 2008, 2:21 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
