Results 1 to 7 of 7
Thread: Charging without a Charge controller
  1. #1
    Join Date
    Jun 2007
    Location
    Williams Lake, BC
    Posts
    3,373
    Default Charging without a Charge controller
    I have a need to connect, short term, a PV or 2 to my camper battery. We are demolishing our old cabin and using the camper for sleeping in, a bit of cooking and showers etc... both my CC's are still in use and I don't want to buy another one for this temporary setup.
    Is there a rule of thumb to use for this hookup?
    ~ 660 amp battery, 25 W and 70 watt panels available. not direct sun as in the shade.
    thanks
    Eric
    100% Off Grid @ 51* 46' N lat 124* 44' W long
    New House system: coming - 2 arrays @ 2240W
    CL150&Epanel 2 @140 W 12v PVs , 24V C&D AT-15P AGM @ 950Ah
    + CL150 2@120W 12 V panels, 24V C&D AT-15P AGM @ 950Ah
    Cotek ST1500W inverter, TBS 30a-24v Omni-charger, Honda Eu3000is,
    Guest cabin system: 3 - 70W panels to SB 2000e CC, with 2 - 100 ah 12v SAFT wet NiCd's , 600W TSW Inverter
  2. #2
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,807
    Default Re: Charging without a Charge controller
    panels in the shade will never charge a battery You have more chance, without a charge controller, of the panels discharging the batteries at night (backfeed)
    660A of battery, 100W of panel, even in full sun, you won't keep up with self discharge.
    http://tinyurl.com/LMR-Solar
    http://tinyurl.com/LMR-BigLug
    http://tinyurl.com/LMR-NiFe
    Grundfos 10 SO5-9 with 3 wire Franklin motor (1/2hp 240V 1ph # 214505 ) on a timer for 3 hr noontime run - Runs off PV
    Powerfab poletop PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe battery | 15, Evergreen 205w "12V" PV | Midnight ePanel || VEC1093 12V Charger | Maha C401 aa/aaa Charger | SureSine | Sunsaver MPPT
  3. #3
    Eric;
    The only thing you can do is put a Voltmeter on it and watch. Together those two panels might produce 5 Amps? Not much for a 660 Amp hour battery (assuming the extra 'm' was superfluous), but even a small charge on a not-so-drained battery can push the Voltage too high. That's really all a PWM does; you'll have to stand in for connect/disconnect. But you don't have to do it dozens of times per second, okay?
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  4. #4
    I have to ask a simple question. Is that battery a 660 amp hour battery or 660 cranking amps? At 660 Ah, that is a massive battery for a camper. Is it is 660cca, running a panel directly to it should keep it charged depending on the amp produced by the panel. I have a couple 100w panels hooked directly to a couple of marine batteries and the most I have ever seen them produce was 17a, and it was short duration.
    ***edit***
    Be sure to run a diode if the panels stay hooked up an night.
    Classic 150 and 3x Kyo 210 and 3 kyo 215s. I have miles to go before I sleep.
  5. #5
    Join Date
    Jun 2007
    Location
    Williams Lake, BC
    Posts
    3,373
    sorry, that is 660CCA as Leper pointed out. Probably in the ~100 A range of most car type batteries.
    Ya, caught in the PV panel trap of hi Voltage/low amperage output.
    It is a 'marine battery' used for the camper and the fishing trolling motor.
    Just ordered a cheapo 10a PWM CC off Ebay. Now I can put the panels in the full sun without too much worry.
    thanks for the quick comments.
    Eric
  6. #6
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,807
    Since that battery is a "hybrid" and contains the worst of both starting and deep cycle, avoid discharging below 70%, or you may not get started some morning !
  7. #7
    Join Date
    Jun 2007
    Location
    Williams Lake, BC
    Posts
    3,373
    Mike I think you are confusing a camper with a "Winnebagel".
    The camper slides on and off the pickup and has its own on board, independent battery, hence the 'marine type' as it is a bit better for long slow use... the main drawback is there isn't enough room for a couple of real deep cycle 6 volt batteries.
    We only get about 2 days before needing to charge up. Water pump gets left on all day, Fridge and water heater are pilot-less units, the furnace fan is the big one and then lights and radio... oh and there is a magic fan that is temperature activated and the seldom used bathroom fan
Similar Threads
  1. MPPT controller and PWM controller charging the same bank of batteries?
    By ILFE in forum Off Grid Solar & Battery Systems
    Last Post: December 11th, 2013, 9:23 PST
  2. Possible over voltage/ over charging or charge controller error
    By Nila in forum Solar Beginners Corner
    Last Post: January 7th, 2013, 11:35 PST
  3. batteries not charging through charge controller
    By lotek in forum Solar Beginners Corner
    Last Post: June 9th, 2011, 11:48 PDT
  4. float (maintenance) charge without a charge controller
    By wagoneer in forum Solar Beginners Corner
    Last Post: August 27th, 2010, 14:40 PDT
  5. Charge set points -SW5548 vs TC60 charge controller
    By dbertheau in forum Grid Tie and Grid Interactive Systems
    Last Post: October 7th, 2008, 22:07 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
