Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: How to hardwire a DC battery charger?
  1. #1
    Default How to hardwire a DC battery charger?
    Hi there, I have some more stupid questions. I was looking at this battery charger: Xantrex TrueCharge2 40Amp Battery Charger.
    I was reading the installation manual for it and I understood 99% of it but I am confused about how to wire the AC-in wires. The manual says it has a 3 conductor pigtail L-N-G to wire into, that I understand but my confusion is caused by how to get these wires connected to the generator that will power it. Do I have to find a 3 conductor 3-prong ac cord and connect them via butt splice connectors?
    The manual says the 3 conductor pigtail needs to be connected to an "AC mains source protected by correct size and type of branch rated
    circuit breaker."
    How do I connect the generator to this battery charger?
    Installation manual:
    http://www.xantrex.com/documents/Bat...1_Rev-B%29.pdf
    As always, much appreciated
  2. #2
    Join Date
    Jul 2007
    Location
    Quetico, Ontario
    Posts
    5,063
    Default Re: How to hardwire a DC battery charger?
    The easyest w to wired it, is wire a AC line cord to it, and plug it in to an out let. Black to L, white to N, and green to the ground lug. Or, hard wire it to an AC breaker, or directly to the genny. Hot to L, white to Neutral, , bare or green to t he ground.
    Hope this helps,
    PS I should add that if you wire directly to e genny, you need to fuse the hot between the genny and the charger if the out p ut from the genny is not fused or breakered for the size of the charger wire. You should also fuse the wire from the charger to the battery with a fuse as big as the charger current (and use wire capable of 40+ amps.)
    Please note, being a moderator does not add any weight to my opinions 300 watts Siemens/BP panels,plus a Sun 90,, making ~400. ~30 amps into Rogue MPT-3024, 450 ah of Trojan T-105, Morningstar ts300 inverter, a Tri-Metric meter.a collection of antique generators, plus 2 Honda eu-1000i's (also a BS2512 IX controller) and assorted other stuff!
  3. #3
    Quote Originally Posted by icarus View Post
    Hope this helps,
    Thank you for the reply icarus, since the battery charger is rated for 40 amps would the wiring from the battery charger to the generator not have to be rated to 40 amps as well? If that is the case what size or gauge wire am I looking at? The run from battery charger to the genny will be less than 15 feet.
  4. #4
    Join Date
    Jul 2007
    Location
    Quetico, Ontario
    Posts
    5,063
    No, the charger put out 40 amps at 12 vdc, the sme load, is only ~4 amps at 120 vac.
    Personally I have wired mine with a #12 line cord, plugged into w fused outlet.
    E 40 am DC side should be maybe #6 or #8. ( don't have a wire chart handy right now, but a google search of " what size wire do I need for 40 amps? I would go one size larger.
    T
  5. #5
    T
    Hi again, I did a search and it appears the answer is different depending on who you ask. One website stated that #8 or 8 AWG was okay to use on a 50 amp circuit so long as it had 3 conductors. Yet another said that #6 was required for a 50 amp circuit. Kinda confused. I agree though, I would always use the larger size if ever in doubt.
    But as far as the connection from the battery charger's pigtail #12 will be fine? I was thinking about using something like this: http://www.amazon.com/Ericson-Weathe...8I/ref=lh_ni_t
    Would I still need to put a fuse on this? Isn't the green wire on the three prong plug considered a ground?
  6. #6
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,939
    The charger is probably designed for a standard household 15 amp 120 VAC circuit... So, a 14 awg wire minimum would be fine.
    12 awg will be OK too--especially if you have a longer run (50-100' or so).
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  7. #7
    Join Date
    Jul 2007
    Location
    Quetico, Ontario
    Posts
    5,063
    To be clear, if you wire the TC 40 with a line cord, and plug it into a fused 120 vac outlet you would be fine with out a fuse. If you somehow hard wire it directly to a generator output that is un fused, (or fused substantially higher than ~ 15 amps then a fuse should be installed on the 120 vac side. The green is the 120 vac ground wire.
  8. #8
    Join Date
    Mar 2011
    Location
    just south of Seattle, Wa
    Posts
    49
    I have 2 TC4012 and had one wired like Icarus mentioned for on grid connection.
    I used the crimper for the AC wire connect. The painful part was to bend all the wires into the small compartment.
    DC I recycled a 20 yr old jumper #6 cable from Canadian Tire. Ended up with 4 paired segment. Bought a harbor freight hydraulic crimper and a bunch of copper lugs. End up with two clamp end pairs.
    For genset I would use 15A or 20A fuse or breaker setup.
  9. #9
    Thank you BB & icarus, great! then I was on the right track. I'm no electrical expert as you might have inferred. So here's how I planned to make the connection.
    Buy this pre-made 25' 12/3 SJO cable: http://www.filmtools.com/25st12sjoeco.html
    cutting off the female end of the cable of course and butt splicing the wires directly into the SC2's pigtail connection. I believe it has the standard 12 AWG wire with Line, Neutral, Ground wires Black (Hot) Neutral (White) and Green (Ground) respectively. I will use about 15-18 feet of it so I can cut it with the cable cutters if need be.
    I planned to fuse the cable nearest possible to the generator end i.e. right before the male NEMA 5-15 plug on the Black or (Hot) wire. I will use this in-line ATO fuse holder:
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    and put a 20 AMP Smart Glow Fuse in it. That way I can visually see if the fuse blows or not.
    I believe that the Green (Ground) wire should be grounded once I plug into the generator's 120v outlet correct? It has two such outlets. I am speaking of the Yamaha EF1000iS generator in this case. As a side note, I believe this generator has an external ground stud which allows you to ground the generator externally but I am hoping this will not be required.
    Thank you guys for your expert advice,
    Jeremy
  10. #10
    Join Date
    Jul 2007
    Location
    Quetico, Ontario
    Posts
    5,063
    Save yourself a bunch of money, and go buy a line cord from your local hardware store. (3 wire), ~$5
    Before you fuse the line from the genny, see if the generator output is already fused. You may not then need to fuse the line cord. You still should fuse the charge positive at the battery,, like with one of these:
    http://bluesea.com/productline/overview/379
    tony
Similar Threads
  1. Inverters with outlets converted to HARDWIRE option..
    By ywhic in forum Off Grid Solar & Battery Systems
    Last Post: September 1st, 2014, 5:47 PDT
  2. battery charger(s)
    By tim p in forum General Solar Power Topics
    Last Post: April 9th, 2010, 15:15 PDT
  3. ? About Battery Charger & Solar Charger
    By tcvb in forum Solar Beginners Corner
    Last Post: March 11th, 2010, 21:17 PST
  4. battery charger
    By Donmuhammad in forum General Solar Power Topics
    Last Post: February 23rd, 2010, 9:55 PST
  5. AGM battery chargers vs normal battery charger?
    By Lloydy in forum Solar Beginners Corner
    Last Post: September 18th, 2009, 21:52 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
