Results 1 to 5 of 5
Thread: C/8, C/10, C/20 Battery Charging Rate???
  1. #1
    Question C/8, C/10, C/20 Battery Charging Rate???
    I am trying to determine the "best" charging rate for my battery bank. I have read through a lot of threads on this forum as well as several FAQs on various websites. One point that seems to be universally accepted is that a current equal to 10-13% of the battery bank's Ah capacity is an optimum rate. I couldn't leave well enough alone and just go with this new found knowledge, I had to keep reading...
    My battery bank is going to be 4 Trojan T-105s connected in series and parallel for 12V so I downloaded the Trojan User's Guide to get their recommendation. The chart below was copied from that guide. What confuses me is on the right hand side of the graph where it indicates "10-13% C20". My understanding is that Cx = Battery bank Ah capacity/x. My interpretation of the chart is 10-13% of C20 which in the case of the battery bank I will have is (450/20)* .1 to .13= 2.25 to 2.925. This seems WAY too small. Any thoughts on what Trojan is trying to indicate in the graph?
    Attached Images Attached Images
  2. #2
    Default Re: C/8, C/10, C/20 Battery Charging Rate???
    I think you're misinterpreting the info.
    450 Amp hours / 20 = 22.5 Amps peak charge current. That's the 5% minimum recommended rate.
    450 Amp hours / 10 = 45 Amps peak charge current. That's the 10% "ideal" peak charge rate.
    The twin line graph shows the change in charge current and cell Voltage in respect to state of charge.
    1220 Watts of PV, OB MX60, 232 Amp hrs, OB 3524, Honda eu2000.
    Ohm's Law: Amps = Volts / Ohms
    Power Formula: Watts = Volts * Amps
  3. #3
    Join Date
    Jun 2007
    Location
    Center of Nowhere, NOR CAL
    Posts
    1,859
    When I saw this chart on the Trojan site, my intrepretation is that it is saying 10-13% of the 20 hour C (Capacity).
    Vic
    Off-Grid, Sys1: 1280 AH 48 V bat, 5.250 KW STC PV, Classic 150, WBjr, MX-60, MN KID, Xantrex Stacked SW+ 5548s; EU6500isa, 21KW Kubota diesel gens, misc Honda Eu gens
    Sys2: 1280 AH 48 V 4KS25 Surrettes, 5.88 KW STC, Two Classic 150s, WBjr, MX-60, MN SPDs, Stacked X SW+ 5548s; Kohler 18 KW LP, EU 3000isa gens, HB DC Charger, Midnite Breakers/boxes. Thanks for this great Forum!
  4. #4
    Thanks to both of you. I think that Vic has pointed out where I made my mistake: C20 is shorthand for "capacity when subjected to a 20 hour discharge".
  5. #5
    Join Date
    May 2006
    Location
    Florida, USA
    Posts
    1,275
    In the graph 'C20' represents the AH capacity at a C/20 discharge current.
    T105's AH ratings yield 225 AH's at a constant discharge rate of 11.5 amps for 20 hours.
    They yield about 180 AH's at a constant discharge of 22.5 amps for 8 hours.
    The curve represents a stage 1 (bulk) charge rate of 12% C20 rating or 27 amps.
    When the voltage rises to 7.05 vdc per battery it is held at constant voltage, stage 2 (absorb), and charge current begins to taper off.
    Normally when the current tapers off to 1-3% of C20 rate (4.5 amps) the charge would be terminated and charger would go to 3rd stage (float) voltage.
    The curve shown takes it higher in voltage, up to equalize levels. I would not do this on a regular basis as it is hard on the batteries.
Similar Threads
  1. battery bank Amp hours, and charging rate
    By ssmith in forum Off Grid Solar & Battery Systems
    Last Post: March 9th, 2013, 8:09 PST
  2. Battery Charge Rate C/8 or??
    By ywhic in forum Off Grid Solar & Battery Systems
    Last Post: June 11th, 2012, 19:34 PDT
  3. Inverter Setting Generator Battery Charging rate
    By Mangas in forum Off Grid Solar & Battery Systems
    Last Post: June 6th, 2010, 20:31 PDT
  4. Genset To Battery Banks Charging Rate
    Last Post: October 31st, 2009, 17:41 PDT
  5. battery hr. rate
    By homerramirez in forum Off Grid Solar & Battery Systems
    Last Post: February 8th, 2009, 17:37 PST
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
