Results 1 to 6 of 6
Thread: Changing fridge from ac to dc?
  1. #1
    Default Changing fridge from ac to dc?
    Hi.
    Is it possible to change the compressor from an AC fridge to a compressor that operates off DC? So far I am looking for a way to do this but nobody seems to offer the compressors alone.
    I thought it would be like just swapping the compressor ac/dc and re-gassing the system, am I wrong? I have a nice horizontal fridge that I would like to change to dc.
    On a side question, I have a Shurflo 9300 pump with a couple of kc65w panels and pump controller working here for about a year, and I wish to know if I should stock on parts that worn out but I am unsure what to get. I wouldn't want to be without water supply if something stops working.
    I live in Laredo.
    Thanks.
    Konstantin.
  2. #2
    Join Date
    Jul 2007
    Location
    Quetico, Ontario
    Posts
    5,063
    Default Re: Changing fridge from ac to dc?
    I would guess that changing the compressors out is going to be more trouble than it is worth.
    As for the shureflo, Parts are fairly easy to come by, I'm not sure I would inventory any, but if I were, I would think that the connector boots, and the valve kits are fairly easy to keep around. If you need more extensive work you can get stuff overnighted from many places.
    Parts B and C on the exploded:
    http://www.windsun.com/Solar_Water_Pumps/9300_parts.htm
    Please note, being a moderator does not add any weight to my opinions 300 watts Siemens/BP panels,plus a Sun 90,, making ~400. ~30 amps into Rogue MPT-3024, 450 ah of Trojan T-105, Morningstar ts300 inverter, a Tri-Metric meter.a collection of antique generators, plus 2 Honda eu-1000i's (also a BS2512 IX controller) and assorted other stuff!
  3. #3
    Join Date
    Jun 2009
    Location
    australia
    Posts
    783
    Where you going to get a DC compressor large enough to use in a full size fridge ?
  4. #4
    Join Date
    Mar 2006
    Location
    SF Bay Area (California)
    Posts
    21,908
    There are some discussions about off-grid refrigerators, for example:
    Solar Refrigerator
    Sunfrost and/or Sundanzer do use a DC powered refrigeration compressor (I cannot find the company name--was it out of Germany?). Depending on the amount of heat that needs to be removed--You would have to size the compressor for that (if they make one the correct size).
    Otherwise, a good energy star refrigerator (or a converted chest freezer to cut power usage way down--see link above), a ~1,500 Watt pure sine wave inverter, battery bank, and solar panels (with backup genset) would be the generic recommendation here.
    In general, the standard energy star refrigerators are about as efficient as the dedicated DC units and 1/2 to 1/3 the price--use that for inverter/extra panels and possibly a longer/more trouble free refrigerator life.
    20x BP 4175B panels (replacement) + Xantrex GT 3.3 inverter for 3kW Grid Tied system + Honda eu2000i Inverter/Generator for emergency backup.
  5. #5
    Join Date
    Mar 2006
    Location
    Posts
    21,908
    I should also add there are companies that make refrigeration compressor kits for the Marine (boats) sector--You may find something there that meets your DC needs too.
  6. #6
    Join Date
    Mar 2006
    Location
    Posts
    21,908
    Goody, just found it "Danfoss Compressors":
    Danfoss Electronic Specification(in pdf format)
    Danfoss Compressor Specification(in pdf format)
Similar Threads
  1. SRP Rebate Changing?
    By daryllafferty in forum Solar Beginners Corner
    Last Post: April 13th, 2013, 7:34 PDT
  2. changing power , do i need 1-O-2 switch
    By prince_77 in forum Solar Beginners Corner
    Last Post: October 21st, 2011, 16:18 PDT
  3. Changing AGM battery orientation?
    By stereoman405 in forum Solar Beginners Corner
    Last Post: February 22nd, 2010, 13:06 PST
  4. Changing Charge Controllers
    By blindref in forum Off Grid Solar & Battery Systems
    Last Post: February 19th, 2010, 17:49 PST
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
