Can I use welding cable from PVs to Charge controller?
Can I use heavy duty welding cable from my PVs to the charge controller?
    Re: Can I use welding cable from PVs to Charge controller?
    You can--but some issues...
    Make sure you fuse the positive lead to the battery (always a good idea). Also, welding cables with their very fine strand wire are difficult to get solid connections with standard binding screws/hardware.
    I would not go out of my way to use welding cables--unless there was a lot of cable flexing involved (not a good idea to mount a charge controller where there would be a lot of movement/cable flexing anyway)... I would use standard NEC rated cable instead.
  • blackswan555
    blackswan555 Solar Expert Posts: 246 ✭✭
    I solder on the fine "stranded" wire, either into a lug or if it is a crimp, tin the wire lightly.
    Have a good one
    Tim
  • bluetick
    bluetick Registered Users Posts: 19
    I was repairing welder cable conections just the other day, the new connections had a quarter arc pad that fit into the screw connections. To gather the fine strands and spread the clamping load.
    If you had a loose connection with solder the heat build up could soften the solder.
    I think making a quarter arc pad from soft copper or steel tubing would be better in a screw type clamp.
  • peterako
    peterako Solar Expert Posts: 144 ✭✭
    Make sure that the cable is acid proof. If not the gassing from the battery or any spil will eat the plastic/rubber and you can have nice fire works.
    greetings from Greece
    Sorry, but I just have to ask: why would you?
    Welding cable: AWG #4, #2, #1 (et cetera) capable of handling hundreds of Amps of current.
    Just what have you got for an array and how far is it to the charge controller? Or am I missing something?
