Can I use welding cable from PVs to Charge controller?
Re: Can I use welding cable from PVs to Charge controller?
You can--but some issues...
Make sure you fuse the positive lead to the battery (always a good idea). Also, welding cables with their very fine strand wire are difficult to get solid connections with standard binding screws/hardware.
I would not go out of my way to use welding cables--unless there was a lot of cable flexing involved (not a good idea to mount a charge controller where there would be a lot of movement/cable flexing anyway)... I would use standard NEC rated cable instead.
I solder on the fine "stranded" wire, either into a lug or if it is a crimp, tin the wire lightly.
Have a good one
Tim -
I was repairing welder cable conections just the other day, the new connections had a quarter arc pad that fit into the screw connections. To gather the fine strands and spread the clamping load.
If you had a loose connection with solder the heat build up could soften the solder.
I think making a quarter arc pad from soft copper or steel tubing would be better in a screw type clamp. -
Make sure that the cable is acid proof. If not the gassing from the battery or any spil will eat the plastic/rubber and you can have nice fire works.
greetings from Greece -
Re: Can I use welding cable from PVs to Charge controller?Leroy Baptiste wrote: »Can I use heavy duty welding cable from my PVs to the charge controller?
Sorry, but I just have to ask: why would you?
Welding cable: AWG #4, #2, #1 (et cetera) capable of handling hundreds of Amps of current.
Just what have you got for an array and how far is it to the charge controller? Or am I missing something?
- 218 Forum & Website
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
