Fusing charge controller
landyacht.318
Solar Expert Posts: 82 ✭✭✭✭
I am trying to answer a question for another person on another forum.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23730185.cfm
Long story short, she had a "professional" install an additional battery and Morningstar 10 amp controller and a KC135 watt panel. This "professional" used no fuses, anywhere.
I know My BlueSky CC said to install a fuse between the panel and CC and between the CC and batteries. I assume this is standard practice on every solar installation, and have said so, but thought I should check with the experts.
Re: Fusing charge controller
read this thread for the main info on what you are looking for,
http://forum.solar-electric.com/showthread.php?t=7020
cheers,
Eric
Simple answer, fuse between the CC and the PV, and a Fuse between the battery and the CC. I like the BlueSea fuse and fuse holder for the battery, simple elegant solution. (You should also have a fuse(s) on any load side of the battery as well).
http://bluesea.com/category/5/21/productline/overview/378
Tony -
Thanks for the confirmation.
- 218 Forum & Website
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
