Battery charger suggestion.
icarus
Solar Expert Posts: 5,436 ✭✭✭✭
Since Xantrex has stopped production of the TC series of chargers, what would folks recommend for a charger for a single 12v ~100ah deepcycle truck camper battery?
It will be powered by gird power, and ideally be on all the time the camper is "in port".
I suggested to these friends that they get a Xantrex TC 10. It seems that the current version starts at 20 amps.
Once again thanks for the help in advance.
Re: Battery charger suggestion.
Tony the TrueCharge 2 series starts at the 20 amp model, but if the remote control is purchased with it, then it can then scale the charger output back in 10% increments. The remote was meant to be available mid 2009.
The new X Truecharge 2 units offer PFC charging, Temp Compensation and a wide input power range between 85 and 260 volts AC 50-60 Hz. So could be used with a generator when out of shore dock.
The TC10 is still available if our host doesnt have them I can let u know of some one in US who does.
Nigel Sunny Spain -
Re: Battery charger suggestion.It seems that the current version starts at 20 amps.
Mike, Thanks,
The IOTA was going to be my next choice. I think I will write to NAWS and see what the story with Xantrex is. They have them listed on the web site as a supplier, but with non on the web pages.
