Most ridiculous power claim ever?
I've seen some good ones, but this has to be the best. I hope it's ok to post this here-it's a 10kW car alternator wind generator. Funny stuff.
http://cgi.ebay.com/10kw-24-29V-WIND-TURBINE-GENERATOR-HD-Flexible-Magnet_W0QQitemZ320448999037QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4a9c3fae7d
I can't believe I wasted 7 minutes of my life watching the video. I wonder when he will be starting a fire in his laundry room..
  • Truth Squad
    Truth Squad Solar Expert Posts: 126 ✭✭
    Re: Most ridiculous power claim ever?
    Small wind is rapidly becoming the carnival midway of renewable energy.
    "Step right up, folks! Lower your electric bill to Zee-Ro! That's right, folks! The electric company will be sending YOU a check each month! You there, sir, would ya like to become a guaranteed winner? Step right up!"
    The Ebay link will go away... This is a converted (looks to be a truck) $1,160 (asking price) alternator with a 350 amp diode bridge replacing a 150 amp bridge. Just attach a 2:1 gear box and add some 15+' diameter blades--you too can generate 10kW @28 volts in 35-55 MPH winds.
    Funny there's no picture of the actual unit in operation - no Ammeter output image either; just Voltage.
    Oh, and they forgot to mention how it will burn out in a few hours time. (I don't see how windings originally designed for a peak 1200 Watts are going to survive putting out 10X that).
    But hey; you can always store the electricity it produces in some lemon batteries*, right?
    I mean, ever see the size of a real 10kW wind genny?
    Scams like this ought to be illegal.
    *The secret to storing RE! All you need is zinc, copper, and a whole lot of citrus fruit! :p
  • john p
    john p Solar Expert Posts: 814 ✭✭✭
    I would love to see how those terminals would be handling about 360 amps..mabe they made from dehydrated low resistance kryptonite. I read in a comic I think somewhere that a 1/8 in terminal and #8 cable made from dehydrated low resistance kryptonite can withstand 679.3 amps at 546.78 deg F.
    Are these "generators "avialable in bulk at reduced prices? I think it the way to power a city or two. Any one know if the 15ft blades can be sent by FEDex?
  • myocardia
    myocardia Solar Expert Posts: 118 ✭✭✭
    Am I the only one who noticed that in the first paragraph, he admits to how little power it actually outputs?
    You are going to need a minimum of 2hp to test this generator in order to see 25V, @1200rpm, I applied 2.7 ohm resistor (dummy load) across pos & neg and I see 7.2amp on my AMP meter.
    Yeah, that's right. For only $1134 (minus blade costs, tower costs, battery costs, electronics costs, wiring costs, among other costs), you too can produce 180 watts @ 1,200 RPM!! 1,200 RPM is only a class 3 hurricane, not a class 4 like their competition requires. Where do I sign up?:roll:
    DoD= depth of discharge= amount removed from that battery   SoC= state of charge= amount remaining in that battery
    So, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoC
    A/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use)
  • vcallaway
    vcallaway Solar Expert Posts: 157 ✭✭✭✭✭
    Well, in his defense he does state this:
    Gear-up 2:1 recommended for low wind area
    So you really only need 600 RPM. So maybe a class 2 hurricane?
    vcallaway wrote: »
    Low wind = not enough power.
    Gears or no gears, you can't harvest what isn't there. (And the gears will use up some of the mechanical energy in the wind.)
  • Kevinb
    Kevinb Solar Expert Posts: 26
    myocardia wrote: »
    [/FONT]
    He added that after reporting me to ebay for telling him he's full of BS...I then reported him for telling me I am uneducated and "going to hell", and for making fraudulent claims :p
    I should post his reply here, it's even funnier than the listing. It's not worth getting sued over though, so I won't.
  • myocardia
    vcallaway wrote: »
    Ahh, I had forgotten that part. So yeah, his product would only require weak class 2 hurricane winds (~100 MPH) to produce the 180 watts he claims it will produce @ 1,200 RPM, assuming his customer went to the extra trouble and expense of gearing it @ 2:1.
    Very true. But after seeing his "workshop", are any of us really surprised that he doesn't realize that?:D
