Experiences with DC-GFP
Hello - Now that NEC 2008 has been out for some time, I wanted to ask what folks are doing in regards to 690.5 Ground Fault Protection (GFP) and some of the products and solutions you have used to address this requirement. I read that there are two exceptions to installing DC-GFP and wondered if folks had any comments on those.
One exception is that pole and and ground mount systems with no more than two paralleled source circuits *and* with all dc source and dc output circuits isolated from buildings shall be permitted without DC-GFP. The second exception is that PV units installed at other than dwelling units shall be permitted without DC-GFP.
Thanks!
Thanks!
Re: Experiences with DC-GFP
I use the MidNite Solar 63 A GF interrupter/indicator in my E-Panel. They also offer an 80 A model (125 VDC). OutBack offers a two-circuit GF interrupter/indicator for one or two PV arrays. Xantrex' XW charge controller has a built-in GF fuse.
HTH,
Jim / crewzer
