Grade B Solar Panels
roks
Solar Expert Posts: 28 ✭
Hi All,
I was wondering what the downside was to Grade B panels. I've been told their electrical specification are are same as grade A but with "cosmetic imparfections".
Is that correct or is there more to it than just cosmetic?
I am offered 0.8USD/watt if I buy 1000watts or more, 130Wp panels, from a company in Ningbo, China.
Any advice will be appreciated.
Re: Grade B Solar Panels
80 cents a watt for what, some non-UL Asi china made off-grade panels with no means for getting warranty service? ( best case )
If its less than 2.30 watt, its not a real deal and likely to be a scam ... nobody is getting real panels for 80 cents a watt -
But, to answer your original question:
As far as I know, B grade panels (such as the Evergreens) are the same as regards warranty, output and quality - they just aren't as perfectly pretty.
And if you check out Solar Guppy's forums, you'll see he likes them. -
Re: Grade B Solar PanelsSolar Guppy wrote: »If its less than 2.30 watt, its not a real deal and likely to be a scam ... nobody is getting real panels for 80 cents a watt
They offered me $1.75/w for grade A.
Anyway, now that you mentioned the word SCAM, I'll try to get a friend of a friend to visit the place and buy and put the stuff on ship himself......rather than the company. -
i don't think he meant that the shipping of it is a scam, but rather the product. -
They sent me a picture and says grade B only has some colour defects.
From your experienced eyes, what do you guys make of it. Would this effect the electrical performance?
Thanks -
Looks typical of a B grade panel. I use B grade Evergreens with no problem at all.
Make sure if you plan to use these in a grid tie or inspected application, that they will need to be UL listed. You are in the U.S.?
Make sure the tolerance is OK. Evergreen B's have the same great tolerance values as the A's. Plus they are made in USA.
I would feel leary about foreign made products, and power tolerances and warranty issues. You do get what you pay for. -
Hi FL SUN,
I will be using them in Bangladesh, so no UL, no inspections, its going to be used to help charge a bank of batteries when there is no mains. Just to try it out so only going to get 6 of 130Wp for a 24v system.MONO or POLY MONO Maximum power (Wp) 130w Maximum power voltage (V) 35.47 Maximum power current (A) 3.815 Open circuit voltage (V) 43.432 Short circuit current (A) 4.28 Number of cells (Pcs) 72PCS Size of module (mm) 1580*808*35mm Maximum system voltage (V) 1000 Temperature Range -40℃C~+80℃C Surface Maximum Load Cap 60m/s(200kg/sq.m) Weight per piece (kg) 8 Junction Box Type TUV certificate Length of Cables (mm) 900mm Frame Aluminum Standard Test Conditions AM 1.5,1000W/m2, 25℃ FF (%) 73%
Thanks -
Thanks for the panel specs. What is the FF (%) 73% value? Just curious if that is the tolerance of (+-)73%? I am not fully in the know - especially metric specs.
Would be good to know if someone here can explain. -
I'm not sure what the tolorence is, I've sent an email to chap, will let you know.
EDIT: Got a reply, tolorence is +/- 5%.
- 626 Discussion Forums/Café
