inverter chargers & charge controllers
Another newb question but I'm trying to put a system together from scratch.
I understand the need for a charge controller but I am perplexed as to the purpose of the charger unit in an inverter charger. Is this redundancy?
Martin
Martin
Re: inverter chargers & charge controllers
You may end up with multiple charge controllers in a system...
1. Solar Panel Charge Controller
2. AC Backup Generator Charge Controller
3. Wind Turbine Charge Controller
4. Water Turbine Charge Controller
5. Utility Mains AC Battery Charger (if Grid Tied).
So--if your Inverter also has alternate inputs (AC Mains and/or Generator AC Input)--it will recharge your battery bank from those alternative AC Input sources.
Think of a UPS (Uninterruptable Power Supply)--The AC Power (when available) charges the battery bank. When AC power fails, then the inverter switches over to DC power and "turns on" to supply off-grid AC power.
The other power sources (solar, etc.) also need their own charge controllers that, in parallel, will recharge the battery bank.
You can put charge controllers in parallel--without too many problems... The big issue is if one is programmed for a higher voltage (or running a equalize stage)--it will "take over" the battery load from the other chargers.
Thanks Bill, I hadn't thought of other charging mechanisms.
Food for thought.
- 626 Discussion Forums/Café
