lead carbon battery PbC Technology
lotek
lotek Solar Expert Posts: 65 ✭✭✭✭
"Axion Power has developed several technological improvements to traditional lead-acid batteries, and owns numerous patents covering them. Its best-known development is the PbC battery, which substitutes activated carbon for lead on the negative electrode of an otherwise traditionally manufactured absorbed glass mat (AGM) lead-acid battery."
http://www.autobloggreen.com/2009/04/16/axion-and-exide-enter-into-battery-agreement/
  • dwh
    Re: lead carbon battery PbC Technology
    Nice. If Exide is licensing it, it's not vaporware. Limited supply and high demand are likely to keep the price up for a while.
    http://www.axionpower.com/profiles/investor/fullpage.asp?f=1&BzID=1933&to=cp&Nav=0&LangID=1&s=0&ID=10298
    "We have been testing laboratory prototypes of Axion's PbC® batteries since April 2004. Our test protocol requires a complete charge-discharge cycle every 7 hours to a 90% depth of discharge. During testing, our laboratory prototypes have withstood more than 1,600 cycles before failure. In comparison, most lead-acid batteries designed for deep discharge applications can only survive 300 to 500 cycles under these operating conditions."
    Hrmm...that might change the math a bit.
    now i'm not going to call that vaporware and i don't know why you mentioned it, but some have issued licenses for vaporware products in the past.
    dwh wrote: »
    Most lead acid deep cycle batteries are only listed to 50% discharge, not 90%. While the test is not on equal footing, I wonder how lead acid AGM's would fare in the same condition. You have to test to the OEM part specs, not beyond, not to the desired.
  • dwh
    mike90045 wrote: »
    Well yes, but testing to failure is a legit test protocol as well.
    yes, this is true and in fact concorde likes theirs tested to 100% dod and is why i don't want to test mine unless one day i become suspicious. the consistent running down of a battery, even for test purposes, will needlessly take away life cycles. they all should come up with 50% dod test parameters. if they use a heavier current for the test, it will have the same effect for failures to show.
