solar water pump for 2" well 55' deep
Does anyone know of a solar pump that will work for this application?
Thank you.
Thank you.
Re: solar water pump for 2" well 55' deep
Look at recent discussions...pretty well covered, recently.
http://forum.solar-electric.com/showthread.php?t=4702
...that's assuming that your water level, like the previous 2" well, is below 20-25 feet from the surface. if the well is 55 feet deep but the water is somewhere in the 20-25 foot (or less) from the surface range, your pump options open up widely. Otherwise the pumps from the prior discussion are all I know of that are available, and provide several good options that will work.
- 626 Discussion Forums/Café
