Industrial Fire Codes and Battery Rooms
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
http://i.i.com.com/cnwk.1d/html/itp/APC_48709_Battery_Technology_for_data_Centers_and_network_rooms.pdf
or http://tinyurl.com/bxepo2
A protected PDF from APC : Fire codes and Battery Rooms
VRLA batterys are happy campers, and easy to design into bakup systems.
(But they are picky eaters, and if you don't feed them just right, they expire.)
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Industrial Fire Codes and Battery Rooms
thanks for posting this mike and for those that would like the link to the osha site, here it is.
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=standards&p_id=10742
- 626 Discussion Forums/Café
