Solar panel company
cizzi
Solar Expert Posts: 109 ✭✭✭✭
I found this company that makes panel locally here in Montreal, they are called centennial solar.. the prices are decent, here's some specs.. can some of you guru's tell me if they are decent panels?
http://www.centennialsolar.com/download/en-crystalline-standard.pdf
Re: Solar panel company
Anyone can print a slick brochure. The test is what do they do in 3 years, when a batch goes bad, like the 120's ? They don't publish a warranty, just a short statement: Contact us for warranty details
Standard for PV, should be 50MPH hail, and 20 or 25 years.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
