Mono-crystaline panels question
cizzi
Solar Expert Posts: 109 ✭✭✭✭
I read somewhere that mono-crystaline solar panels are better for northern areas with snow, for example where I live (Montreal). Is this true? And why?
Re: Mono-crystaline panels question
Mono-Crystalline are slightly more efficient (per sq. meter) so your panels can be slightly smaller for the same surface area. So, they can cost a bit more per watt...
Some people also like the uniform black color of mono-crystalline vs the "shattered blue glass" look of the poly-crystalline panels.
In general, both are equally good and long lasting (assuming they come from a reputable manufacturer)... If neither of the above are issues for you--then you generally purchase on a $$$/Watt (delivered to your door).
I dont know, but I'd think if they were better by design, all of the panels would be made in this way ...
maybe they have a different "wattage derating for temps" or so
but overall - it seems like marketing speak to me ...
cheers
al
- 626 Discussion Forums/Café
