315Wp, 305Wp or 300Wp required
Please can someone tell me if these panels exist and where can i buy the panel (worldwide). Only one panel is required for this project at this stage but will require a large quantity at a latter stage.
Re: 315Wp, 305Wp or 300Wp required
Wow !! Even the 200 W panels are pretty big and awkard to handle. (about 40lb apiece)
Would 2, 150W work, or are you looking to use 1 panel as a patio cover ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
i'd be curious too as to why this range of pvs for if you can't find them very well now and assuming you find some now, just how are you going to find some later? -
The only ones in that power range I know of are the Schott Solar ASE 300 DF/G panels. I believe they are available in power ranges of 280 - 320w per panel. They are 74.5"x50.5" and weigh 107# each. Just Goggle "Schott Solar". -
Check this site www.sunpowercorp.com
They have commercial solar panels 305 Watt and 315 Watt (315 is not available in USA) - spec. here
Their product are really good.
-Martin
