Marine battery disconnect
I’m looking at using a rotary marine battery disconnect switch for my off grid battery bank.
http://bluesea.com/category/1/productline/3
Its rated 350A cont. 1750A inrush.
My 12VDC input inverter is 2kW Cont. 4.5kW Surge. Bank of 4 GC2 220ah Batteries, 4/0 Cabling, 300A fuse.
Does anyone have experience with using this type of switch for off grid installations?
Thank you,
Jerry
Thank you,
Jerry
Re: Marine battery disconnect
although i don't have one, i haven't heard of any complaints and it should work just fine. -
it is a newbie question.
when or where battary disconnect is need for off grid installation.I’m looking at using a rotary marine battery disconnect switch for my off grid battery bank.
Thank you,
Jerry -
If nothing else, a a battery disconnect switch comes in handy when assembling or maintaining a system.
I used the 350 A model for several years with no problems. A heavy duty model is also available: http://bluesea.com/category/1/productline/4
Even better would be a big DC rated breaker with a high AIR rating (20 kA to 50 kA).
HTH,
Jim / crewzer -
I use one to switch between my old and my new battery banks. Having the ability to switch in 1, 2, or both is really handy.
