Desperately seeking off grid solution for sunpower 210 panels!
Re: Desperately seeking off grid solution for sunpower 210 panels!If the grid is up and the XW is doing a pass through charge of the batteries from the power generated by the GT, will it correctly charge the batteries?
(previous post seemed to indicate that is would not).If that is the case, the secondary charge controller is needed between the XW and the batteries to actually handle the charging duties.If that is NOT the case, the XW will handle all the battery charging duties and the secondary is then in parallel and is only used to detect battery overcharge (backup).
http://www.sunwize.com/info_center/pdfs/sma_sunnyisland%204248.pdf
Sunny boy islander
- 218 Forum & Website
- 185 Solar Information links & sources, event announcements
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 600 Discussion Forums/Café
- 298 In the Weeds--Member's Choice
- 73 Construction
