Adding panels to system
woodrose
Registered Users Posts: 7 ✭
I have a 48v system with a 16 -12v panels mounted on a Zomeworks tracker, feeding 4-48v circuits through a trace junction box, and then through a RV controller to a 48v battery bank.
I want to add a one more 48v set of stationary panels to the system and run it through the junction box and am concerned about the set not being equal in capacity to the other circuits due to the panels being stationary.
Do I need to safeguard the stationary panels against getting a flow from the ones on the tracker?
Re: Adding panels to system
What kind of controller are you using,, and how? MPPT?
Tony -
In general, the Vmp of the panels is more or less related to its operating temperature... For MPPT (and PWM) controllers, you can parallel strings that face different directions (east/west/tracking/etc.) and you will probably only loose a percent or two of power vs using a dedicated controller.
However, if the new panel string would exceed the max current/power rating of your existing controller--then you would need another anyway.
I found a report from one of the MPPT Grid Tie inverter manufacturers that wrote a white paper about east/west panels sharing one controller and posted the link here a couple times--can't find it right now.
The controller is a RV Solar Boost MPPT. 30A so it has the capacity for the addition. -
Re: Adding panels to systemTony
Are you sure?
30 amps @ 48V is ~1500-1600 watts
You have 16 solar panels now, if they are 100 watt panels you would be at the controllers limit. You didn't mention the panels type/wattage -
Re: Adding panels to systemSolar Guppy wrote: »Are you sure?
I have 85 watt BP (6 year old } panels.
I was using the BP spec of 4.7 A at load in my computations which would equal 18.8 A for 4 strings. The peak amps on the controller reads 22 A so I figured I a 25% increase would be OK. Am I missing something? -
My Solar Boost MPPT CC has a "name plate rating" of 25 A BUT that is at Isc ...not Imp..In reality I have a 20 amp CC not 25... SB has done a good sales job here...
you might want to check your panel(s) Isc rating(s) and double check them against the manual for your CC's max amperage... or you may be well over the max.
EJ
- 628 Discussion Forums/Café
