Asking for help
HI TO ALL.;)
5 -7w lights 12v
Laptop-watt?just plan on avg for one.....4hr day.
Small t.v. 12v with dish? 4hr day.
What system for off grid would i need?
THANK'S
5 -7w lights 12v
THANK'S
Re: Asking for helpHI TO ALL.;)
5 -7w lights 12v
THANK'S
Sorry.
Loc- AK summer, just something that can be for short term.
Have a honda 2000 for backup also.
Thanks again. -
Re: Asking for help
Is this a 24/7 house, or a weekend cabin ? What city ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Asking for helpIs this a 24/7 house, or a weekend cabin ? What city ?
Cabin for 24/7 for 3 weeks outside Anchorage.
Thank's:D -
Re: Asking for help
for only 3 weeks a year, solar is a Expensive investment. you may want to consider a small generator and battery backup system, you can buy a generator for the price of 2 panels.
There is a long thread here
http://forum.solar-electric.com/showthread.php?t=3144
that you should read, figure out some load numbers for your use, and then we will have something to work with.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
5 -7w lights 12v
THANK'S
lets see:
4 pcs - 7w lights x 8hrs on: 220w
notebook 35w x 4hrs: 140w
tv: 60w x 4hr: 240w
TOTAL: 600wh per day for 2 days reserve (assumption) = 1200wh
1200wh are 100ah in 12V - so you'd need a 200ah battery bank, cos you dont want to go below 50% depth of charge.
to replenish the 50ah (daily consumption) you'd need about 150-200w "nameplate" worth of solar panels - if you can get 4 hrs of full sun - if not - you'd need 200+w
then you'd need a charge controller and an inverter and the batt's and the PVs.
so, doing the math - a gen is a better option, b/c managing a battery bank off-site is risky (they prob. cr@p out on you the next time you get up there ) and expensive
also you might want to consider the risk of PVs and stuff get stolen (a gen is way more stealth in a cabin far off)
probably not what you wanted to hear
cheers
al
- 626 Discussion Forums/Café
