What are Used Solar panels Worth?
I have two hot water solar panels, they are made by Radco products Inc, Model 408P-HP and have a 32.28 Sq. Ft. of surface area each (46 x 101.5 inches). They are about 15 years old. The sealing caulk for the glass is dried up, but it appears I could remove the the tops of them easily enough clean and reseal them with new caulk. Any thoughts. I was hoping they be worth about $400 each, since new panels are well over $1,000.
Re: What are Used Solar panels Worth?
The only real value is the copper inside them. I've seen panels last year like this for 100.00 bucks cash and carry, a warehouse full an no takers.
Only the most die-hard solar do-it-yourself type would buy them for re-use and honestly, at 15 years, there at end-of-life. Its not worth the labor to repair them, all of course is IMHO -
Aloha, at 15 years old they are just worth the copper. They start leaking and with the gasket drying up, you would need to find a person off the radar that would not consider the tax credits and buy new ones. Try Craigslist and try for $250.00 each, take $100.00
Frank
