Solar Array Field Catch Fence
Mangas
When I built my system, I decided to build a "low intensity" rabbit fence (minimal shadow orientation) wired to T-Posts surrounding the array field.
I was concerned about high winds some day blowing loose debris into the field as well as grazing critters. At the time some people, including me, thought it was probably overkill. The investment was about $500.
Well, the past two days we had continuous 60 - 70 mph high wind gusts. The "fence" caught several large pieces of horizontal flying debris that could have done serious damage to one or more of the panels.
Just thought I'd pass along my expeience.
    Re: Solar Array Field Catch Fence
    i'm glad your forethought saved you some aggravation and money. you had doubts if you were wasting your time and now you know better.
  • Telco
    Telco Solar Expert Posts: 201 ✭✭✭✭✭
    Neat. Pics?
    This sentence is extra characters so the board will allow the post.
