Future of solid state sodium glass lithium battery by Goodenough?
softdown
Solar Expert Posts: 3,821 ✭✭✭✭
Been plenty of hype. Yet the hype is getting old and seemingly nothing has materialized yet. What do you guys think? Guy is 95 years old, could be running low on time. https://news.utexas.edu/2017/02/28/goodenough-introduces-new-battery-technology
Looks sketchy, using a isolated optical bench as a computer stand !!Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Here is another small piece, a very small piece: https://pubs.rsc.org/en/Content/ArticleLanding/2017/EE/C6EE02888H#!divAbstract
If legit, the technology would profoundly change the world. I wonder what is going on.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Youtube video on the subject, there are several: https://www.youtube.com/watch?v=YAg_8iCLIIwFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 626 Discussion Forums/Café
