Genius US company makes iron battery that competes cost wise with lithium!
softdown
Solar Expert Posts: 3,820 ✭✭✭✭
Not the video I wanted but you get the idea. ESS makes iron/saltwater flow batteries that go into 40' shipping containers. Thus offering 50 kilowatts of energy. "Enough to supply a block for four hours." Plus the price competes with lithium!
Simply built, the parts are available at Home Depot. Did I mention that the price competes with lithium?
https://www.youtube.com/watch?v=ovZXBXtG9no
I won't live long enough to see this in RVs.
Is there a version that could fit on my wall in my garage?
8 kW Enphase micros AC coupled to a SolArk 12K -
At the moment, focused more on the industrial scale - A pity, as no reason it couldn't be on a residential scale:
https://www.essinc.com/energy-storage-applications/off-grid-microgrid/
A 17,000 lb semi-trailer full of gear gets you a 40 kWw / 400 KWhr system ....Offgrid in cloudy PNW
MacGyver'ed museum collection of panels, castoff batteries and generators - ready for state of art system install .... parade of surviving and dead generators: H650, Ryobi 900, Briggs and Scrap Iron 2000, H2200, H3000, Kubota 3500, Kubota 4500, Onan 7500
Although not exactly the same electrolyte, the zinc bromine flow battery offering from Redflow is of residential scale.
https://redflow.com/applications/residential/
This article has some interesting information with regard to flow batteries not being practical in small scale residential applications.
https://www.sciencedirect.com/science/article/pii/S1876610216310566
Random reading material should one be interested.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Who needs a generator for off-grid low solar periods - just haul your battery trailer into town and have it recharged :-).
Porschephanatic said:
I was being a bit sarcastic when making the thread title. Don't you think that "iron batteries" should be less expensive than "lithium batteries"?
Lithium batteries can be made from a broad array of materials, few of which are cheap. Iron batteries are made of iron with nickel plating. From here - that looks like it should be relatively inexpensive.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
softdown said:I was being a bit sarcastic when making the thread title. Don't you think that "iron batteries" should be less expensive than "lithium batteries"?
I believe the video said the parts were available at HD - guessing the storage unit perhaps? It was made by a young dreamer. They are typically more interested in spin than reality.
As far as I know, iron solar batteries are comparable in size to lead solar batteries. This video depicts an industrial battery. Going off of memory here.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
softdown said:I believe the video said the parts were available at HD - guessing the storage unit perhaps? It was made by a young dreamer. They are typically more interested in spin than reality.
- 626 Discussion Forums/Café
