Solar Charging a 48V go kart
2»
    If A & B are where the AC power comes in, do not place a jumper across them.  (well, I would not)  The green disk thing looks to be a surge suppressor (oddly with a diode silkscreen under it??),  if you are putting a jumper across it, you could just leave it in, or remove it to give yourself more room.
    But that layout looks not quite right to me, for a voltage select jumper set.
    Gauge, 16ga wire would work, 17 is a non-standard size, 16 is the next larger
  • Functional_Artist
    Functional_Artist Registered Users Posts: 17 ✭✭
    Well, I figured, lets give this a try.
    I removed the screws from both of the ends to open the charger up. The housing is an enclosed box.
    I figured the circuit board would just slide right out.
    Nope, there are components that are soldered to the circuit board & also glued to the inside of the box.
    But, luckily the area that I needed to work with was near one end & pretty easily accessible.
    So, first I clipped the Lima bean looking thing out (as per the instructions)
    Then, I soldered in (2) 16g. jumper wires (also, as per the instructions)
  • Functional_Artist
    OK, now If it's supposed to be, preset to a 49V top charge, like I specifically ordered, right from the factory
    …& NOT 50.4V or 54.6V like most 48V lithium chargers are.
    What should the voltage be coming out of the DC output plug?
    ...49V?
