Enphase IQ8 intentional islanding
bill von novak
Solar Expert Posts: 891 ✭✭✭✭
Apparently the IQ8 inverters from Enphase will have the ability to intentionally island and run loads on a home with no grid power.
Anyone heard anything about this? The only way I can see this working is with a "gateway" to the grid including an isolating breaker/relay - which would be a fairly big modification to a home system. Especially given that the meter + load panel is a common monolithic component in many home systems.
https://runonsun.com/~runons5/blogs/blog1.php/residential-solar/what-i-saw-at-enphase-mind-blown
I agree - technically this has been doable for a long time. But getting safety approvals might be a show stopper
Also nice would be if they produced a compatible super capacitor inverter that could provide a few seconds of startup current - so you could start and run your standard 1KW well pump with ~1KW of solar panels (but no batteries).I am available for custom hardware/firmware development
jonr said:I agree - technically this has been doable for a long time. But getting safety approvals might be a show stopper
