Rinnai wall mount furnace
just starting
Registered Users Posts: 235 ✭✭✭
does anyone use one of the rinnai wall furnace I bought a 21000btu- at my altitude its more like 16500btu, I figured worst case it would be on 24/7 and use 1350wh of power.
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
No but I use the Empire propane furnace from Home Depot. It uses zero power. I have not used it in 10 years and back 15 years ago it was required as our building department required a 2nd source of heat besides the wood stove. These days I tell my clients to use a mini-split and try and get that approved as the 2nd source. Good Luck!"we go where power lines don't" Sierra Nevada mountain area
It's temporary just for two years, I'm avoiding 240 at all costs.200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Why? It is pretty standard to use 240 these days. Is it because you are building?"we go where power lines don't" Sierra Nevada mountain area
Yes I'm building and I have no need if all it is for is a well or a mini split, I live @ 10100' so ac maybe 3-5 days out of the year, and a well can easily be pumped into a cistern with 4 panels and a good D.C. Pump, I haul water less than a mile now from a spring.i did however take your advice on a D.C.frigde and a D.C. Freezer so I can shutdown my large inverter and just use a 300w all the time. So at 1000$ or less for a 24v inverter 3000w vs 4K for a good 240v3000w inverter/ charger can get a whole well pump that can be run from multiple supply, I'll use a 11000 watt array and a dmppt450 for heat and ac and have 10kw of usable power per day even on the cloudiest day. I'm building a net zero passive home. Just don't have the ability to cut wood anymore200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
I sure would love to know how you get 10Kw out of an 11Kw array on the cloudiest day"we go where power lines don't" Sierra Nevada mountain area
I'll make some videos, when it's together next year around this time200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
- 626 Discussion Forums/Café
