Looking for Busbars for a LiFePO4 battery bank
DustyDusty Posts: 218Solar Expert ✭✭✭
I've been looking at BMS-controlled LiFePO4 batteries to replace my AGM battery bank when the time comes, and the battery mfrs stress the importance of every parallel battery cable being the exact same length as the others.  So, I plan to use a positive and negative busbar that will allow me to combine the outputs of the batteries and ensure that each battery's pos. and neg. cables are identical length.
The mfr recommends at least #4 wire from each battery, and I intend to use #2 with or without lugs on the busbar side. But the input to the XW4048 is 4/0 lugged wire, so the busbar has to be able to incorporate that.  The busbars I've seen on NAWS don't appear to support a wide enough range of cable gauges.
The problem I'm having is finding code compliant, covered, 8-stud busbars with 3/8" studs (the maximum # of batteries that will fit in my enclosure is 6).
My battery enclosure is 42"L x 18"D x 26"H, so the busbars need to be small enough to fit in that enclosure. The XW 6048 is mounted to the side of this enclosure, so the busbars cannot be outside of it. The batteries will be in two rows of 3 at the bottom of the enclosure, and there is room above the batteries for the busbars.
If anyone has set up a similar LiFePO4 battery bank, would you please provide where you got the busbars?  Thanks!
XW6048, 3.4KW PV, Grid-Tied, always tweaking.
  • karrakkarrak Posts: 304Solar Expert ✭✭✭✭
    Are you making the battery from single 3.2V cells or 12V blocks with integrated BMS or something else?
    What is the configuration, how many batteries in series and parallel?
    Simon
    Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
    32x90Ah Winston cells 4p8s (24V), 4kW Latronics Inverter, 1160W of Solar Panels, homemade MPPT controller
    Homemade BMS https://github.com/simat/BatteryMonitor
  • DustyDusty Posts: 218Solar Expert ✭✭✭
    edited August 2 #3
    Simon
    The batteries I'm looking at are 48v, 69Ah with integrated BMS as drop-in replacements for my AGMs.  They cannot be rigged in series--only parallel, so it will eventually be 6 parallel batteries in the enclosure.  I may start out with only three, but I'm told that additional batteries can be added later without the balancing worries of FLA or AGM.
    So I will only need two busbars capable of accepting 6 battery inputs of 2-4 gauge cable but support output to the inverter's 4/0 cable.
