What would happen?
dazza159dazza159 Posts: 4Registered Users
Question.
What would happen if you used another dc source on an mppt charge controller in the solar panel port?
I'm thinking of the 12v power socket in my car to the solar input. A kind of dc to dc charger when I'm driving as my panels aren't fixed on.
Thanks.
  • PhotowhitPhotowhit Posts: 4,662Solar Expert ✭✭✭✭
    Without regard to your direct question, the voltage would be too low to charge through a MPPT type charge controller.
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • dazza159dazza159 Posts: 4Registered Users
    Ok thanks, just thought I'd ask the question 👍
  • mike95490mike95490 Posts: 7,792Solar Expert ✭✭✭✭
    And if you use a higher voltage, it won't respond the way a PV panel does as the MPPT circuit try's to control the power.
  • mcgivormcgivor Posts: 2,058Solar Expert ✭✭✭✭
    You could, if the battery that needs chaging is 12V, connect directly to the car battery, the alternator will do the rest, just be careful if it's an AGM, flooded would be fine, always incude an appropriate fuse to protect the wiring.
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
