Should you DIY a Solar Installation
cow_ranchercow_rancher Posts: 104Solar Expert ✭✭✭
It appears that Mother Earth News thinks the Solar installation industry does not add much to the cost of a solar system.
What are your thoughts?
https://www.motherearthnews.com/renewable-energy/diy-solar-with-a-solar-panel-kit-zbcz1601
10%    Really?
Rancher
  • EstragonEstragon Posts: 2,838Registered Users ✭✭✭✭✭
    That article really doesn't say much at all.  10% might be about right if I bought panels etc at a box store vs getting something installed, but it's really apples and oranges.  I saw $3/watt on sale at Canadian Tire recently.
  • cow_ranchercow_rancher Posts: 104Solar Expert ✭✭✭
    Tire stores install Solar Systems?
    Rancher
  • mcgivormcgivor Posts: 2,202Solar Expert ✭✭✭✭✭
    edited October 2017 #4
    They do sell tires but are actually stores like Target and Walmart, with an automotive shop attached.
    1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery bank
    Home Depot also sells pv online.  $514CAD for a 150w panel.  $2770CAD for a 400w DIY kit.  Like CT, they don't install and mainly sell small 12v systems.  At those prices, installed prices from a solar specialist are likely close, but it's apples and oranges.
    I priced out gear locally from a specialist when I did my system about 3 years ago.  It was  nearly double (not including labour) versus what I paid NAWS.  CAD/USD is lower now, so I expect it's still roughly the same.  On top of the extra cost for the local specialist, I wouldn't have had to do all the reading and planning I did, so there would probably also have been the cost of murdering at least one battery bank in the learning curve.
  • Dave AngeliniDave Angelini Posts: 4,008Solar Expert ✭✭✭✭
    The local brick and mortar solar business is over twice my price. I unfairly compete as I teach the user how to install by text or e-mail Outback or Schneider.
    They do a great job of going to these remote rural locations and doing the work. They are great for people who do not have basic handyman skills. I require that and pass on the bid to them. They have alot of stock and a wharehouse. I have few spare 24 and 48v inverters and a cc or two. My stock all comes from two of the largest warehouses in the Americas.  I don't change the price but rather charge a flat fee anywhere in the world.
    I am what the financial guys call critical mass. I like the work and the people, but if they get weird, I go outside and enjoy my life offgrid!
    Plenty to do here for 25 years now  :)
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
  • oil pan 4oil pan 4 Posts: 751Solar Expert ✭✭✭✭
    That mother earth article could be accurate if you used $10 to $20 per watt panels prices.
    Only then could the install price be considered insignificant.
    What I have found is the installers mark up the hardware to almost double it's original cost, then double that number again to install it.
