Charging battery’s I figured I could charg
Whoops 2/0 g cableOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
A 175 amp fuse or breaker is a common size in mid sized 48 volt inverters. 250's are common on 24 volt inverters. I see you have 8 battery strings so without rereading the whole thread, just deducting you system is 48 volts.
Hope I'm not completely out in left field with this comment.
If you have a 48 volt battery bank/bus--A good starting point (of course, use the manual for the "correct" information):
- 3,600 Watts * 1/0.85 AC inverter eff * 1/42.0 volts battery cutoff = 100.8 amps
- 100.8 amps * 1.25 NEC derating for continuous current = 126 Amp minimum Breaker/Branch Circuit Rating
@wellbuilt
Your system has a 175 amp inverter breaker, so you'll want a 175 amp fuse on each string of 8 batteries.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Thanks for The informationOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
I've got 4 deep cycle batteries connected to a 1500 watt inverter my battery bank reads 16v on a meter but read 11.2 on my inverter I also have a charge controller hooked to it why is my battery bank reading 11.2 and when I put the meter directly to my bank it reads over 16?
Have you measured the voltage on the inverter DC input?To much voltage drop in wiring? Need short and heavy cables from inverter to battery bank. At full power, your inverter could draw over 130 amps.Also 11.2 volts at the battery is suspect too. Possibly the battery is under charged, drawing too much current through your inverter for battery bank size (too small of bank), or aging/sulfating battery bank.BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
