In Need of a good DC clamp meter
solorone
Solar Expert Posts: 257 ✭✭✭
I have a Fluke #36 meter that will not stay fixed to read DC amps. I can read - and + and get the difference fairly reliably with large loads. It seems to be a Fluke flaw, as through the years I have bought 2 more of them used at a good price, and each has the same problem. I need to clamp 500 MCM.
Notice I did not say cheap, but a good price would be helpful.
Keep your eyes open, I found a Fluke 376 For $125, pretty much unused. The guy did maintenance for wind turbines and got a replacement each year from company and pretty much never swapped them out...
Where are you located? I'd be sure to check Facebook market place and letgo or whatever phone app is hot today. I see more things on FB market place than I do on Craigslist these days.
The Ideal meters are a good quality trade grade tool http://www.idealindustries.ca/products/test_measurement/clamp_meters/760_series_clamp_meter.php1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks folks, I will take a closer look at the FB market, never paid much attention to it before. Cheers.
