Renogy Rover 40A CC Mppt error code
FabianFabian Posts: 59Registered Users ✭✭
I have a Renogy Rover Mppt 40A charge controller which is displaying an error code: ACr
It is not working. Display turns on, but just displays "ACr." Does not respond to buttons. Does not appear to charge batteries.
What can I do to repair the CC or remove this error code?
what does this error code means?
  • mcgivormcgivor Posts: 2,058Solar Expert ✭✭✭✭
    Do a reboot, disconnecting solar first, then battery, Walt 5 minutes connect battery, wait for the boot process to complete, if everything seems normal connect PV. Just a suggestion, electronics sometimes get caught in a loop, a reboot is the first thing  I would do.
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
