Leave charging / floating or cut off for no use and high heat
I have an RV system I have posted here about a bit and had a question on storage / non use and high heat and what that may do to batteries.
I have 3 12v 200Ah AGMs in the hold in the RV. I have to go away for about 10 days on a business trip and we are going to be in a heatwave daily temps are expected to exceed 110f.
I have no power requirements in the RV while I am gone and I can completely shut down any drains of power.
My question is should I just shut the system down ? Batteries are full and floating at the moment, thoughts ?
  • mcgivormcgivor Posts: 2,211Solar Expert ✭✭✭✭✭
    edited July 23 #2
    Strange things can occur when unattended, 10 days is not long, my vote is shut down for peace of mind.
    1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery bank
  • EstragonEstragon Posts: 2,840Registered Users ✭✭✭✭✭
    AGMs tend to have low self-discharge rates, so I'd agree shutting down is the better choice.
  • tr0ytr0y Posts: 86Solar Expert ✭✭✭
    Thanks guys ! Shutting down now
