battery cable
petertearai
Solar Expert Posts: 471 ✭✭✭✭
Dont know why i hadn't thought of it before . Just got some multi stand battery cable 95mm squared , [ 3/0 in number size i think ]. from the scrap metal depot .
Almost new , $5.00 per meter .
Usually around $25.00 from the cable merchants new .
2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
That's where I try to get all of mine.
