SW4024 EEPROM ERROR
fasterski
Registered Users Posts: 13 ✭✭
Hi everyone,
I was wondering if anyone has ran into issues with Schneider SW4024 in terms of EEPROM ERROR. I put the unit in standby yesterday and then switched it into operating mode. It came up with ERROR F55. (SCP control unit) . I went to turn off the battery power. Turned it back on and the unit starts up and then just goes dead (some of the lights go on, FAN spins up, and then all lights off). Anyone has any suggestions to try before I contact Schneider?
Do a cold reboot, everything disconnected wait as long as possible to allow capacitors to discharge, start with battery on first , 5 minutes would not change much in any persons life......much1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Happy to report that the problem is solved after having the thing off unplugged from DC and AC for a day. Thanks mcgivor.
Nice to hear, as always you're welcome, giving is more rewarding than taking.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
